It is currently Sun May 03, 2015 6:13 am
 Post subject: Fedora newb question
PostPosted: Sun Nov 14, 2004 6:06 am
Hey All,
I've decided to give linux a try, and i am looking at fedora core 3.
Since im such a newb, i dont know which to download from the torrent.
The
Fedora Core 3 Source iso images for i386 or
Fedora Core 3 Binary iso images for i386
(http://torrent.dulug.duke.edu/)
And lastly, how do i check the md5sum?
Thanks,
Victor
PostPosted: Sun Nov 14, 2004 6:17 am
7yrs+11,000 Posts
7yrs+11,000 Posts
I belive the source iso's will work.
PostPosted: Sun Nov 14, 2004 8:37 am
The binary image is your best bet. It contains a pre-compiled (ie., working) distribution. The source image contains only source code that you must compile yourself ... not a task for a novice linux admin.
 Post subject: Re: Fedora newb question
PostPosted: Sun Nov 14, 2004 1:02 pm
victorl19 wrote:
Hey All,
The
Thanks,
Victor
Definitely the Binary ISO's. For MD5Sum, you need an MD5 Checksum app for Windows. Don't forget to save the .md5 file of the ISO's when you download it.
