It is currently Tue Mar 03, 2015 11:41 pm
 Post subject: Question on Red Hat RPM's
PostPosted: Mon Nov 08, 2004 10:17 am
Regarding PHP on Red Hat 9.
I want to upgrade my PHP installation to 4.3.9, and then eventually to 5.
On rpmfind, the newest version I could get that was specifically for RH9 was 4.2.2-17.2.
I assume that I'd be asking for trouble if I tried to install a Fedora 2 RPM on my RH9? Do I have to install the standard tar.gz?
Thanks.
 Post subject: Re: Question on Red Hat RPM's
PostPosted: Mon Nov 08, 2004 10:43 am
Personally I like to live on the edge: I sometimes mix and match RPM distros/versions. As long as the dependencies are satisfied there is rarely a problem.
PostPosted: Tue Nov 09, 2004 2:51 pm
Hehe...ok, thanks. :)
I guess it depends on how bad I want it. :)
