It is currently Wed Apr 01, 2015 8:41 pm
 Post subject: SuSE 9.1 Pro
PostPosted: Sat Oct 30, 2004 8:13 am
I wanna install it, when I do, it installs the packages.When its done with CD1 it doesnt ask for CD2. I assume that its gonna do it after the first boot. But, when I boot the machine, I get L10101010101010101 (or somethng like that) and about 40-50 lines mor of it. The bootloader is istalled on the MBR of /dev/hdb (the default drive, it also has windows on it.)
PostPosted: Sat Oct 30, 2004 9:07 am
You're not completely installed.
Where did you get those disks from??
PostPosted: Sat Oct 30, 2004 10:07 am
That error is generally a problem with LILO ... I'd check that our first.
PostPosted: Sat Oct 30, 2004 10:33 am
Yes, I know I'm not completely installed, it didnt ask for the second disk, is this normal? And yeah, I know its a LILO error, any ideas on how to fix it.
I got the disks from a friend.
PostPosted: Sat Oct 30, 2004 10:54 am
This is almost impossible to diagnose remotely, because there are a thousand things you could have done incorrectly. You've given us almost no information to work with, and I don't even know where to start.
I'd reinstall, if I were you.
PostPosted: Sat Oct 30, 2004 11:34 am
well I really CANT give you THAT much info because this is what happens. When I used GRUB, I got the error message "GRUB geom error", and I cant log on to the system in any way. (Same thing happens when I install it on the MBR of /dev/hda)
PostPosted: Sat Oct 30, 2004 2:13 pm
Just a thought, but why are you installing LILO??
PostPosted: Sat Oct 30, 2004 3:15 pm
Given that he can't use GRUB either, I'd say the question is irrelevant at this point. :)
Something is fubared, but I'll be damned if I can guess at this point. :? Sorry.
PostPosted: Sat Oct 30, 2004 4:06 pm
well sure...my thought was though, that since the SuSE installer defaults with grub...why not leave well enough alone and lessen the chance of having some obscure error creep into this.
My only thought is, repair the MBR, delete what partitions were created and start over again.
PostPosted: Sat Oct 30, 2004 4:07 pm
That would be quicker than a complete reinstall. :)
Where is my head today? :?
PostPosted: Sat Oct 30, 2004 4:29 pm
I cant install Mandrake ethier, I guess I'll have to boot from a floppy disk?
