It is currently Fri Mar 27, 2015 3:13 am
 Post subject: 64-Bit Linux
PostPosted: Fri Oct 15, 2004 8:33 am
I pick up my 64-bit Bad Boy hopefully today...
Yes. There will probably be several Linux distro's...one will be 64-bit.
Which one though?
PostPosted: Fri Oct 15, 2004 9:29 am
Gentoo.
I need someone I know to test the waters for me. So .. thanks! :D
PostPosted: Fri Oct 15, 2004 10:31 am
LOL!!
PostPosted: Sun Oct 24, 2004 1:29 am
Jipstyle wrote:
Gentoo.
Where can I get it?
PostPosted: Sun Oct 24, 2004 2:09 am
Wolfmann wrote:
Jipstyle wrote:
Gentoo.
Where can I get it?
Maybe: http://www.gentoo.org/main/en/mirrors.xml ?
PostPosted: Sun Oct 24, 2004 11:29 am
iron colbinator
iron colbinator
I installed the debian "unstable" for amd64 architectures on a test server at work and the difference is certainly noticeable to my previous 32-bit platform. I'm going to benchmark both the 32-bit and 64-bit performance on the same hardware to find out how big the difference really is.
Most of the major distributions have varying amd64 support (basically all of the 64-bit AMDs and the EM64T Intels), I'd say all of them have ia64 support (Itanium), not to mention the other various 64-bit platforms.
I had a couple of issues with USB on the kernel I'm using, but I think some flux is to be expected. I could probably recompile my own kernel and it would go away. Debian provides two kernels by default -- one "generic" (preferred for AMD) and one "em64t" (preferred for Intel). The install was pretty smooth (just like a regular debian install).
I'd just take the distribution you're most familiar/comfortable with and find the 64-bit version. Otherwise, go with the distribution you're most interestd in using.
