It is currently Fri Mar 06, 2015 10:24 am
 Post subject: Mac Install CDs...
PostPosted: Tue Sep 14, 2004 6:33 am
Hey all, I was wondering how, or even if, you can successfully burn a working bootable backup of the Mac OS X Panther CDs. If you know, please post. Thanks.
PostPosted: Fri Sep 17, 2004 9:01 pm
You insert the first install disk, open Disk Utility, and create a disk image. Eject the install CD and then burn the image to a blank CDR. Repeat for the other two. Should work, as it wil create exact duplicates of the original disks.
