It is currently Mon Mar 30, 2015 3:05 pm
 Post subject: got fedora up and running
PostPosted: Sat Sep 11, 2004 1:00 am
team psycho or sumthin
i almost got this done in my sleep,i like the way that fedora checks your CDs before you install...disc 2 was a bad burn.
i am using gnome but how do i install KDE now....and switch between the two?
also how do i set up single click for the desktop? i am too used to the single click in windows so doubleclicking is unnatural for me.
and if it is possible can i reconfigure grub so that windoze is the default OS instead of fedora?
PostPosted: Sat Sep 11, 2004 5:17 am
I think you just install kde from the add/remove programs deal under system tools. To switch you have to do something when you log off, I can't remember I haven't used fedora in a while now.
PostPosted: Sat Sep 11, 2004 7:26 am
Yea..it's done through the add/remove applet.
You could problably also go to a command shell and do a yum install KDE
There's a desktop switcher somewhere in the start menu where you can set the default. In either case, you can also choose this at the login prompt.
PostPosted: Sun Sep 12, 2004 4:27 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Its very easy to burn bad startup disks. A professinal programer sent me some linux disks and they where all bad.
 Post subject: Re: got fedora up and running
PostPosted: Sun Sep 12, 2004 10:24 pm
Try this or use Konstruct to compile from source.
There used to be an applet to switch between KDE and GNOME but I don't know if it is being developed anymore. Your best bet would be to setup the Login Manager under the KDE Control Center (gdm, the GNOME login manager may already be setup). Then just logout of one enviroment and log into the other.
In KDE the single-click option is in the KDE Control Center >Peripherals>Mouse. (labels may be different in Fedora)
Edit /boot/grub/grub.conf
change default=0 to default=1
(assuming windows is the second title line in the file)
