It is currently Sat Mar 28, 2015 11:55 pm
 Post subject: linux server
PostPosted: Sat Sep 04, 2004 11:16 am
i currently have several computers networked in my house all running windows xp as their operating system. i was wondering if it would be possible to setup another computer running linux on the network and be able to access it from my windows computers? if possible, how would i go about doing this?
PostPosted: Sat Sep 04, 2004 11:58 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Yeah, when you go to install linux, click server, and it will give you a option for a file sharing server, which will work with windows computers. You can also acess this through a custom setup.
PostPosted: Sat Sep 04, 2004 12:22 pm
which version of linux?
PostPosted: Sat Sep 04, 2004 12:33 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
red hat linux fedora core 7.0 - 9.0
http://www.redhat.com/
PostPosted: Sat Sep 04, 2004 1:50 pm
thanks for the info
 Post subject: Re: linux server
PostPosted: Sat Sep 04, 2004 10:04 pm
Yes, you have to setup SAMBA though in order to share files across your Windows/Linux network. To date, I have one Windows XP machine that gets its files from a remote Linux box running SAMBA. All of my Linux boxes use a Samba viewer.
The following distros rock:
* SuSE
* Mandrake
* Fedora (not really on my top, but it's a n00b distro)
SuSE may cost you some dough, but you get telephone support, updates, and not to mention solid driver support. I would recommend SuSE over Fedora anyday though.
Two things: As Gamerfreak says, make sure that you choose the Server option. However, keep in mind that you need Samba installed. You can get rid of the Database Options (unless you want to run a database) as well as Apache (if you want to host a local website). Samba's your primary key here, as you'll need it.
To reach your Server from the desktop, you can either Remote Access the desktop (I think KDE has something to that effect) or, if you don't mind command line, SSH to it.
PostPosted: Sun Sep 05, 2004 5:42 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Piddy716 wrote:
thanks for the info
welcome
