It is currently Thu Jan 29, 2015 8:13 pm
 Post subject: FreeBSD 5.x stable branch created
PostPosted: Sat Aug 28, 2004 12:57 pm
In the lab!
In the lab!
The FreeBSD CVS tag "RELENG_5", better know as FreeBSD-STABLE, has been created.
Currently the stable branch is empty but after the 5.3 release (tag RELENG_5_3_0_RELEASE) is built all future versions of FreeBSD 5.x will be considered stables releases.
FreeBSD 5.x will no longer be considered an experimental new technology version not ready for production environments. They now belive that 5.x will be just as stable if not more than the 4.x line.
I've sticked with running 4.x for my test server becuase it has been stable. However I'll probabbly now switch over to the 5.x line since it's now considered stable.
The 5.3 release should be a good one. They've done a lot of work to improving performance on the network stack. It's now almost completly multi-threaded which means on multi-processor systems will get a huge improvement for network apps like web and database servers.
The other big thing is a project that will allow FreeBSD to use windows network drivers, called Project Evil. This will allow almost every wired and wireless network card that has windows drivers to now work with FreeBSD even if the company doesn't make FreeBSD drivers.
PostPosted: Wed Sep 01, 2004 11:47 am
Bitchin' Fast 3D Z8000*
Project evil seems promising. From what I gather off some ml's, an 'insulator' is used to sort of wrap the windows .inf and .sys files. Unfortunately, I haven't found a website discussing it in greater detail. Do you know of any?
PostPosted: Wed Sep 01, 2004 1:27 pm
In the lab!
In the lab!
nope I've looked high and low but there doesn't appear to be an official website or anything discussing it. It's a true BSD project :) They spend their time working on the code not that website to hype the project.
Ok cheap shots aside ;)
copied from here:
Quote:
> What in the world is Project Evil?
Project Evil (aka the NDISulator) is a special binary compatibility
layer for the FreeBSD kernel that lets you use Windows NDIS drivers
for network adapters with FreeBSD/ia32.
What does Project Evil do:
- Provides a small Windows PE file relocator/dynamic linker
to allow Windows .sys files to be interfaced with the native
code.
- Provides a utility to parse Windows .inf files to extract
device identification data and registry keys.
- Emulates large chunks of NDIS.SYS, HAL.dll and ntoskrnl.exe
with native FreeBSD kernel routines.
- Interfaces the NDIS packet/buffer model with the BSD ifnet/mbuf
model, making an NDIS driver look like an ifnet interface to
the FreeBSD kernel.
- Supports PCI and cardbus devices (and PCMCIA too, eventually).
What doesn't Project Evil do:
- Provide support for USB network devices (this would require
emulating portions of USBD.SYS and portitions of the Windows
I/O model outside of the NDIS API).
- Support Winows modem drivers (this would mean duplicating
big parts of ntoskrnl.exe).
-Bill
PostPosted: Wed Sep 01, 2004 3:29 pm
Does 'insulator' == 'wrapper', or is it different somehow?
PostPosted: Wed Sep 01, 2004 4:13 pm
In the lab!
In the lab!
It's technically a wrapper but you just don't throw the drivers in a folder someplace and the network card magically works.
You run the windows foo.sys and foo.inf files through a program that builds a c++ header file and special data file for the driver. You then have to compile the driver which links together the wrapper part with the special data file and builds a FreeBSD kernel object(basically a driver).
the ndis man pages explain things pretty good.
PostPosted: Thu Sep 02, 2004 9:27 am
Personally, I think that this is a big problem with a lot of oss projects. Who has time to read through three years of list emails just to figure out how a project is suppose to work.
OTOH, I would rather work on code instead of a website myself.
PostPosted: Sat Sep 04, 2004 11:24 pm
That is fine by me (although a wiki or something discussing the design w/ some diagrams would be nice). If anything, lately, I wish more OSS ______'ers would just shut up and code. I'm getting sick of reading so much fluff and crap.
PS... I think what happened is that I started to respond and left the post open on my desktop. In the meantime, you responded, but I didn't see it until just now. So, really, I'm not talking to myself. :)
PostPosted: Sat Sep 04, 2004 11:29 pm
Yeah, that went well.... :)
Quote:
Sorry, no data found for `ndis'.
