It is currently Sat Apr 25, 2015 6:57 pm
 Post subject: How do i get the vi editor tutorial
PostPosted: Thu Aug 26, 2004 11:41 am
I have used it before but i can not rember what the command is, i need to get fimiliar with it again.
As what programing language do you use to program in linux, and what compilers could i use.
PostPosted: Thu Aug 26, 2004 12:23 pm
Should be just VI (or was it vi) and then you're file name.
Should be able to do just a man vi
Just a thought, but why not use pico or nano??
PostPosted: Thu Aug 26, 2004 12:40 pm
Hey pico works when i had mandrake 9 on here it did not work
Anyway the tutorial i was talking about, is built into to vi, and just gives you a start in working with VI
PostPosted: Thu Aug 26, 2004 1:29 pm
You can install pico on your own if you want, either via a download and compile or with some sort of package your particular flavor might have.
nano is pretty much a clone of pico though and that might be installed instead....as an example...Redhat will install nano, but Drake will have both (and I think nano is installed by default)
PostPosted: Thu Aug 26, 2004 2:38 pm
iron colbinator
iron colbinator
Should be the command vitutor or vimtutor (depending on which vi flavor you have installed).
 Post subject: Re: How do i get the vi editor tutorial
PostPosted: Fri Aug 27, 2004 8:39 am
nick0danger wrote:
How do I get the vi editor tutorial?
Here's a link that has some good info:
http://www.chem.brown.edu/instructions/vi.html
I've been using it as a quick 'cheat sheet' for commands. :)
PostPosted: Fri Aug 27, 2004 8:57 am
Look into vim, as it is a bit more powerful than vi (unless your distro soft links vi to vim).
anyway...
http://www.unb.ca/documentation/UNIX/tips/vim/
C, sometimes C++, perl, i know enough java to bullshit my way through it.
As for compilers...gcc baby. That is probably the most prevalent and well supported compiler under GNU/Linux systems.
