It is currently Fri Jan 30, 2015 10:52 am
 Post subject: Android Jelly Bean tablets support 64GB SD cards?
PostPosted: Sun Mar 09, 2014 6:32 pm
Is it the tablet itself generally or the OS (in this case Android 4.1 Jelly Bean) that determines whether a tablet can support a 64GB SD card or not?
I have an Acer A110 tablet with Jelly Bean 4.1 but the manufacturer specs say it only supports up to 32GB. I don't want to try (for I'd have to buy a card first) without knowing for sure if it will work or not? But is this more a software limitation or a hardware limitation? I got the tablet only a year ago, when 64GB cards were out, but still somewhat newer.
 Post subject: Re: Android Jelly Bean tablets support 64GB SD cards?
PostPosted: Thu Mar 20, 2014 11:45 am
It could be both. Think of 48 bit addressing and large hard drives a few years ago. Last I knew, Jellybean supported cards that size though, however the tablet may need to format it to a file system it can use
I'm thinking the disclaimer was predented as a result of them only able to test 32 gig cards.
