It is currently Sat Apr 18, 2015 4:10 pm
 Post subject: Owncloud how-to in current issue
PostPosted: Tue Jan 14, 2014 3:25 pm
For those that have the current issue with the Owncloud tutorial, I have a question. I get through all the first linux commands fine, through the
mkdir data
command. The ones that follow, chown, I know sets permissions. But the one for the config and the apps directory returns an error that says that that file or directory don't exist. I have deleted the VM file and started over, thinking I typed something wrong before this step, and it did the same thing the second time around. And ideas here? I would really like to get this working on the VM, and if it works well there build a small server to host this.
Thanks in advance...
atr
 Post subject: Re: Owncloud how-to in current issue
PostPosted: Sun Jan 19, 2014 1:32 pm
My experience with owncloud (on rasberry pi, freebsd, and on Ubuntu server) has been less than great. I would not recommend using Owncloud in the least. Have you considered Seafile?
PostPosted: Mon Jan 27, 2014 8:57 pm
Do you have a link to the exact instructions you're reading and can you post the exact output of the message you're receiving...
Usually this is something simple you can work out with what's being output, or making an assumption based on the instructions.
