It is currently Sat Apr 25, 2015 12:54 am
 Post subject: dumbass question
PostPosted: Thu Aug 12, 2004 3:04 am
team psycho or sumthin
i have been up for about 30 hours so forgive any misspellings
does one have to know how to program to use linux or a linux based OS?
PostPosted: Thu Aug 12, 2004 5:03 am
Forum's 3dfx Zealot
Forum's 3dfx Zealot
well a number of us do.
If you looking for a linux to try out with out having to edit info on your hard drive you can try Knopixx which is a linux that runs off a cd.
you can download it from there website for free
http://www.knoppix.org/
 Post subject: Re: dumbass question
PostPosted: Thu Aug 12, 2004 8:04 am
no. it depends on what distro of linux you use.
like jawa said, it helps to be proficient at some text editing programs...like vim, or (egads!) emacs.
PostPosted: Thu Aug 12, 2004 6:13 pm
Nope. That is not a requirement at all.
Knowledge of operating systems, file systems, and hardware is necessary for some distros, but there are others that install easily without this knowledge (ie., Mandrake) ... and still others (as Jawa mentioned) that don't even need to be installed. Knoppix runs linux right off your CD-ROM without changing anything in your system. :)
I agree with Jawa ... try the Knoppix CD and see if you are comfortable in linux ... if so, then you can make the next step to a HD based install ... and from there, the world is yours! :D
PostPosted: Thu Aug 12, 2004 7:47 pm
thanks it took and hour to download but it works......infact i posted this while using knoppix and it will take a little getting used to, i do like the layout
PostPosted: Thu Aug 12, 2004 8:21 pm
Sweet! Glad to hear it. :) If you have any questions, feel free ...
PostPosted: Thu Aug 12, 2004 11:40 pm
im on a roll.....i just found debian.....i think i want to setup a multi-boot it will be XP 98 and debian.....i know i need a seprate partition for 98....and read that linux(based OS) dont like NTFS so im gonna make 3 partitions just for the hell of it......but wich OS do i need to install first? the partitions are gonna be 30gb/XP 2gb/98 and 8gb/debian.....i forgot i am also gonna make a 3gb partition on my second HD for a fat32 swap...are you confused cuz i am :lol:
edit:
do I need to set my BIOS to cache my BIOS or does debian/linux work like windoze in that it just uses the drivers to run hardware?
PostPosted: Fri Aug 13, 2004 4:52 am
Bitchin' Fast 3D Z8000*
I would partition as follows.....
hda1: 7 gigs fat 32
hda2: 25 gigs ntfs
hda3: 8 gigs ext2 or ext3
hdb1: 250 or so megs linux swap
hdb2: 3 gigs fat32
You have to put win98 on the first partition. This also assumes that the speed of hda and hdb are pretty comparable. If hda is significantly faster put the linux swap on hda4. I bumped up hda2 because 2 gigs is just useless - especially since win98 will consume 700+ megs. What if you want to transfer a movie or a few directories of mp3's or something?
The easiest installation order is win98, winxp, debian.
All operating systems use drivers to run hardware devices. You don't need to change your bios, except you might want to change the pnp os setting to "non-pnp os".
PostPosted: Fri Aug 13, 2004 6:01 am
hda1: 7 gigs fat 32
hda2: 25 gigs ntfs
hdb2: 3 gigs fat32
ok, how do i format the debian partition? should the install disk have the formating tools?
i put 98 down for 2gb just cuz it will be a "bare bones" install and i have gotten 98 down to just under 400mb, and all the programs i will be running with 98come up to another 500mb that should leave around 1gb for swap...but i might add more just for the sake of defraging purposes
both hard drives are the same model, anyways half the fun is playing around to find out what works best rite
i just asked this question cuz i have never installed a linux based OS before...i know when ya set the BIOS to nonCACHE windows is happy
thanks
PostPosted: Fri Aug 13, 2004 6:05 am
forgot.....i just use the 2nd HD for my archive( all my install files) and for my pagefile (virtual memory)
PostPosted: Fri Aug 13, 2004 11:57 am
Yes, try 'cfdisk' in debian. The easiest way is to leave just leave whatever partitions are not used as free space. When installing win98 just create the 2gig partition and leave the rest free. Then install xp and create it's partition and leave the debian paritition as free space. More fdisks that way, but it is easy.
PostPosted: Fri Aug 13, 2004 1:28 pm
If those seem too hard for you (and me :shock:) then you should try pico or, its clone, nano. They are very simple to use with just a few easy keyboard shortcuts and they have help at the bottom of the terminal.
PostPosted: Fri Aug 13, 2004 3:42 pm
That is right.... during the debian install, the only text editor available is nano (if thigns haven't changed).
PostPosted: Fri Aug 13, 2004 6:03 pm
thanks im gonna take a nap and get started....i already pre-partitioned my 2nd HD and left blank space for a debian format to use as a archive
PostPosted: Tue Aug 17, 2004 10:54 am
No, I am very proficient with vim, I hate emacs only because I don't know it well.
PostPosted: Wed Aug 18, 2004 9:22 pm
...i cant get debian to work i have tried the install 3 times and have figured out two things
1. microsloth has me spoiled
2.i dont have a high enuff geek factor rating to make it work
But i will not give up trying...i am going to download every damn OS i can find and go insane making them work
PostPosted: Thu Aug 19, 2004 7:25 am
Try Slackware. Jawa (one of our regulars) says it is quite easy for a beginner to install .. you can be our test candidate! :D
PostPosted: Fri Aug 20, 2004 5:27 am
while downloading slackware i found this quiz
http://bbspot.com/News/2003/01/os_quiz.php
deleted useless stuff
WTF am i doin wrong.............
PostPosted: Fri Aug 20, 2004 6:08 am
You're trying to use HTML on a bbCode enabled board.
PostPosted: Sat Aug 21, 2004 2:13 pm
slackware is too much of a hassle....but i got mandrake up and running.....but it wont support my trackball (PS2 or USB) so im gonna go buy a cheep-o mouse
