It is currently Thu May 23, 2013 10:39 pm
 Post subject: I'm baffled
PostPosted: Mon Aug 02, 2004 8:00 pm
Professional Dork
Professional Dork
[global]
workgroup = WOOD
netbios name = canvasback
server string = Samba Server
security = user
guest account = pcguest
map to guest = Bad User
map to guest = Bad Password
#============================ Share Definitions ==============================
;   idmap uid = 16777216-33554431
;   idmap gid = 16777216-33554431
;   template shell = /bin/false
;   winbind use default domain = no
[fah]
   comment = fah
   path = /fah
   guest ok = yes
   browseable = yes
   writable = yes
Yet for some reason when I try to access the share from Windows, I can't connect to it.
The network path \\canvasback\fah coiuld not be found
Help me.
 Post subject: Re: I'm baffled
PostPosted: Mon Aug 02, 2004 10:49 pm
Do you see the share under Network Neighborhood? Check the permissions over again, as well as the user/owner of the folder. Make sure that the user and owner of the folder is the user that's trying to access the share itself. That could be the problem.
PostPosted: Tue Aug 03, 2004 4:37 am
Professional Dork
Professional Dork
I see the system in Network Neighborhood, but not the share itself.
When I click on the system, I get
"\\Canvasback is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions.
The network path was not found."
PostPosted: Tue Aug 03, 2004 6:37 am
My initial thought is pcguest does not have appropriate permisions applied throughout the entire share.
I beleive all you need to do is apply the right perms with chmod and it has to be applied to that directory and every directory under it.
PostPosted: Tue Aug 03, 2004 7:54 am
iron colbinator
iron colbinator
1. As furball said, check perms on /fah
2. If you haven't already, add pcguest to your samba users (smbpasswd -a -n pcguest) -- though I would expect to see bad username/password if this was the problem
3. Try the "guest only" option (although you do have guest ok, which should be sufficient, and is the same as my "public" option)
4. Check samba log (mine is /var/log/samba/log.smbd and log.nmbd) after attempting to visit share, see if it has any info
My incoming share has the following options:
[incoming]
comment = put files on me
read only = no
path = /usr/local/share/samba/in
public = yes
browseable = yes
writable = yes
guest only = yes
Some of those are redundant, but you get the picture.
My /usr/local/share/samba/in directory is world writable.
PostPosted: Tue Aug 03, 2004 9:02 am
Professional Dork
Professional Dork
/fah is set to 777
I tried adding some redundent flags in my smb.conf
Still no workie
[root@canvasback samba]# cat smbusers
# Unix_name = SMB_name1 SMB_name2 ...
root = administrator admin
nobody = guest pcguest smbguest
The only thing in my log is:
[2004/08/03 11:58:41, 0] smbd/server.c:main(757)
  smbd version 3.0.3-5 started.
  Copyright Andrew Tridgell and the Samba Team 1992-2004
I have added a hosts file on my other workstation so it can find canvasback and I can ping by name to the machine.
PostPosted: Tue Aug 03, 2004 3:34 pm
Just because I've been burned by this before...Did you do that via a chmod or chmod -R
The first just sets the folder only. The later will set everything in /fah including the folder itself.
PostPosted: Wed Aug 04, 2004 4:37 am
Professional Dork
Professional Dork
Excellent question. I'm pretty sure it's 777 all the way down.
I'm starting to think it's a network issue, since the log file isn't even showing anything
PostPosted: Wed Aug 04, 2004 11:32 am
Professional Dork
Professional Dork
Would it help if I used
Security = share
PostPosted: Wed Aug 04, 2004 12:30 pm
I dunno.
Doesn't that point to groups that are setup on there??
PostPosted: Wed Aug 04, 2004 12:43 pm
Professional Dork
Professional Dork
We have one box at work that serves as a gateway between networks. People on a private LAN can see the share from \\Samba02, when all the files are on \\Samba01. Samba02 sees the share on Samba01 as an NFS share, and shares it to Windows.
When you create files from the private network, the file is created by "nobody".
Anyhow, I remembered that I had turned on the firewall when I installed. I turned it off, and it sorta works.
Now I can browse the share , I just can't map a drive to it.
PostPosted: Wed Aug 04, 2004 6:15 pm
iron colbinator
iron colbinator
I think HK47 mentioned in chat that this is working now. :)
PostPosted: Thu Aug 05, 2004 4:36 am
Professional Dork
Professional Dork
Yeah, it didn't work at 4pm, and it did at 8pm. :wtf:
