It is currently Mon May 20, 2013 12:22 am
 Post subject: Augen netbook with Android 2.6
PostPosted: Sun May 08, 2011 5:29 am
Augen netbook with Android 2.6....want to replace with a scaled down Win XP or Unbutu any easy way?
It has a 8G SSD ....
Thanks...
 Post subject: Re: Augen netbook with Android 2.6
PostPosted: Sun May 08, 2011 7:28 am
Try nLite. It has been used to cut Windows XP down to a few hundred megabytes. However, if your netbook has an ARM processor, then you'll need to wait for Windows 8. Windows and Ubuntu are not ARM compatible (as far as I know.).
PostPosted: Sun May 08, 2011 1:35 pm
MMM...have to check and see if ARM processor,...
Thanks...will try nLite
PostPosted: Mon May 09, 2011 6:39 pm
Still having a problem...over riding the Android 2.6....any other suggestions?
PostPosted: Mon May 09, 2011 8:44 pm
Sure. If you want help installing Windows, try the Free Clinic.
There is a sticky in that folder that explains how to get help .. considerably more information is required.
PostPosted: Tue May 10, 2011 6:59 am
Thanks will go there.....
