I'm trying to install virtualbox on my Ubuntu 10.04 laptop.
I download the package, and try to install it. it comes up with some "can't compile kernal" message and tells me to run some command as root. I run the command, and it tells me to look at some error log. Here is the log:
Log wrote:
make KBUILD_VERBOSE=1 -C /lib/modules/2.6.32-22-generic/build SUBDIRS=/tmp/vbox.0 SRCROOT=/tmp/vbox.0 modules
/usr/src/linux-headers-2.6.32-22-generic/scripts/gcc-version.sh: line 25: gcc: command not found
/usr/src/linux-headers-2.6.32-22-generic/scripts/gcc-version.sh: line 26: gcc: command not found
/usr/src/linux-headers-2.6.32-22-generic/arch/x86/Makefile:81: stack protector enabled but no compiler support
make[1]: gcc: Command not found
test -e include/linux/autoconf.h -a -e include/config/auto.conf || ( \
echo; \
echo " ERROR: Kernel configuration is invalid."; \
echo " include/linux/autoconf.h or include/config/auto.conf are missing."; \
echo " Run 'make oldconfig && make prepare' on kernel src to fix it."; \
echo; \
/bin/false)
mkdir -p /tmp/vbox.0/.tmp_versions ; rm -f /tmp/vbox.0/.tmp_versions/*
make -f scripts/Makefile.build obj=/tmp/vbox.0
gcc -Wp,-MD,/tmp/vbox.0/linux/.SUPDrv-linux.o.d -nostdinc -isystem -Iinclude -I/usr/src/linux-headers-2.6.32-22-generic/arch/x86/include -include include/linux/autoconf.h -Iubuntu/include -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -msoft-float -mregparm=3 -freg-struct-return -march=i586 -ffreestanding -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -fno-omit-frame-pointer -fno-optimize-sibling-calls -pg -I/lib/modules/2.6.32-22-generic/build/include -I/tmp/vbox.0/ -I/tmp/vbox.0/include -I/tmp/vbox.0/r0drv/linux -D__KERNEL__ -DMODULE -DRT_OS_LINUX -DIN_RING0 -DIN_RT_R0 -DIN_SUP_R0 -DVBOX -DRT_WITH_VBOX -DVBOX_WITH_HARDENING -DCONFIG_VBOXDRV_AS_MISC -DRT_ARCH_X86 -DVBOX_WITH_64_BITS_GUESTS -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(SUPDrv_linux)" -D"KBUILD_MODNAME=KBUILD_STR(vboxdrv)" -c -o /tmp/vbox.0/linux/.tmp_SUPDrv-linux.o /tmp/vbox.0/linux/SUPDrv-linux.c
/bin/sh: gcc: not found
make[2]: *** [/tmp/vbox.0/linux/SUPDrv-linux.o] Error 127
make[1]: *** [_module_/tmp/vbox.0] Error 2
make: *** [vboxdrv] Error 2
Any ideas?
Ted
