It is currently Fri Mar 27, 2015 4:45 pm
 Post subject: Fastest booting linux OS to use a media center with boxee
PostPosted: Fri Mar 26, 2010 4:51 pm
As my long subject says I am looking for the linux os with the fastest boot time that will run boxee. And instructions to install boxee on auto boot. I only know Ubuntu linux so anything else I get lost in.
Thanks!
 Post subject: Re: Fastest booting linux OS to use a media center with boxe
PostPosted: Fri Mar 26, 2010 7:38 pm
Then why are you asking for alternatives with a faster boot time?
and AFAIK, you're building from source in other distros.
PostPosted: Fri Mar 26, 2010 11:29 pm
TravBv2.0
TravBv2.0
If speed is what you're looking for (on bootup or otherwise) then Ubuntu isn't a great place to look. It's like trying to build a race car out of a Buick LeSabre. Ubuntu is meant to be "comfortable" for lack of a better term and easy to use, even by those who aren't terribly tech-savvy. Unfortunately, much like GM's cars, Ubuntu has had some odd quirks and can be buggy for some (ooooooh, domestic auto burn!)
For quick bootup and a minimal system for running boxee, you'll want to check out Gentoo or Slackware. Patience, Jack Daniels and 3 to 5 sleepless nights should suffice to scratch the surface.
:lol:
PostPosted: Sat Mar 27, 2010 7:37 am
First off, Thanks.
Second, How would I compile it for gentoo?
PostPosted: Sat Mar 27, 2010 8:57 am
Everything you need to know about compiling and installing gentoo.
PostPosted: Thu Apr 01, 2010 12:37 pm
bootwise, Ubuntu is nowhere close to booting fast.
Now you CAN make apps load faster by installing 'prelink'.
My Firefox loads in 2 or 3 seconds .
Glenn Condrey
PostPosted: Wed Apr 28, 2010 6:53 am
Take a look at the link below - its an excellent article about how to install Boxee on Jaunty.
http://lifehacker.com/5406563/build-a-c ... dia-center
Personally I use XBMC standalone with Ubuntu 9.04 for my HTPC / Media Center. Jaunty is rock solid and has excellent boot times. In comparison to 9.10 and 10.04 versions of Ubuntu (I know because I have tried and there is simply too much going on under the hood) it to this day remains stable. Just remember to patch it up to the latest levels before installing your media center.
Hope this helps...
