It is currently Sat Apr 18, 2015 8:24 pm
 Post subject: Clean install
PostPosted: Wed Mar 10, 2010 4:21 pm
Hello,
I just received a comp from a friend but had to get a new (used) hdd. I want to try ubuntu 64. Do I reformat as a secondary drive on my xp machine and install it then or put it in the new comp and do the reformat/install there?
Thanks,
Trent
PostPosted: Wed Mar 10, 2010 5:16 pm
The install will ask you where you want to partition and format.
You may want to start with a unpartitioned space though, or use something like Wubi.
PostPosted: Wed Mar 10, 2010 9:18 pm
I've got the 2nd drive in the xp machine. I went into comp management and initialized when the pop up came. it shows as disk 1, basic, online with the full drive unallocated. When I right click the option is to make it a dynamic drive. Is this what I need to do? I want to format and install Ubuntu and then move it to the other comp.
PostPosted: Thu Mar 11, 2010 1:13 pm
If you're going to put Ubuntu on that drive, don't even bother doing anything with it under Windows. The Ubuntu installer will handle all the partitioning and formatting.
PostPosted: Thu Mar 11, 2010 1:22 pm
OK, Thanks!
