It is currently Sun Mar 01, 2015 1:42 pm
 Post subject: Knoppix Live CD Help-
PostPosted: Wed Jan 19, 2005 9:49 am
Yo people i recently recieved a message from a friend about Knoppix, because as some of you know ive had problems with Fedora Core 2 and 3 (cant config X) so yea... so anyway i download Knoppix Distro of Linux, which is a live CD
so, anyway! im asking if anyone here who uses it knows how to partition a drive thats on a computer while running Knoppix on it.
Like, gimmie a walkthru of commands and stuff
Much Obliged
-Zambini
PostPosted: Wed Jan 19, 2005 9:59 am
I'd rather be modding!
In the KDE GUI under the K start (lower left corner), look under utilities, or system or what not. There should be QTParted. Its a GUI version of "Parted"
Its still very beta IMO - I have had trouble with it.
Manta
PostPosted: Wed Jan 19, 2005 3:47 pm
TY Mr. Manta ;) will try today and post results
PostPosted: Sat Jan 22, 2005 6:20 pm
lol sorry it took so many days, ive been busy this week
found qtparted v9.4.4
so how do i make a boot thingy for Knoppix?
or can i
ps: i tried the thing here
http://KILLMEPLEASE.org.nz/misc/knoppix-install.html
but it doesnt work it says no such command as knx-hdinstall
PostPosted: Sun Jan 23, 2005 8:03 am
Folding Momerator
Folding Momerator
Hey Zambini, do you get MPC? Will Smith has what appears to be a really good article on Linux. I just started reading it, if you have the Feb issue, check it out.
PostPosted: Sun Jan 23, 2005 9:05 am
or can i
Are you trying to install Knoppix onto your HD? Or do you just want to run Knoppix from the CD? You don't need to install Knoppix to use qtparted.
BTW - when you see "-" it normally has a space before it like this list command:
ls -s
not ls-s
Hope that helps.
If you want to install knoppix, I have more modern instructions, that page is for version 3.3 I think.
Let me know.
Manta
PostPosted: Sun Jan 23, 2005 9:21 am
ya i wanna installl knoppix on my hard drive
i tried "knoppix-installer"
and that brings me to a partition thing and says "which partition would you like to use" then it goes to a partition manager and then i dunno where to go from there
PostPosted: Sun Jan 23, 2005 9:42 am
The command that I have is "sudo knoppix-installer"
Thats probably qtparted starting up and trying to get a partion ready for your install.
Is this a single boot system or multiboot? Are you wanting to put knoppix on its own drive (I highly recommend this if you are going to dual boot with Windows).
Oh wait - are you at a window that has a list of options like "configure installation", "start installation" etc...?
Hmm...looking....ok, are you at a window that says "Create Partition"?
I just need a bit more info.
Manta
PostPosted: Sun Jan 23, 2005 9:44 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Believe it or not i am going to be speaking with the pres. of knoppix on wensday on our local radio station computer show where they have no idea what they are talking bout.
PostPosted: Sun Jan 23, 2005 10:07 am
There really isn't a pres. so to speak I don't think, but what is the person's name
I might have a few questions you can ask.
Manta
PostPosted: Sun Jan 23, 2005 4:02 pm
hey blondie-
while at LAX i picked up the feb 05 issue (the one with Will's article in it) and i am going to try to install Debian
unsuccessful linux installs:
Fedora core 3
fedora core 2
Successful (kinda)
Knoppix, although i do not know how to install to hd yet... :/ but i did mess with the kpartition manager thing so i got my other partitions done with ;) and i did learn some great vocabulary with Will Smith's article too, so i might be successful yet
Manta Ray-
Im @ a DOS looking screen, it says some stuff about Knoppix installation requirements not met, please create a partition etc. Im runnin kpart (WHENEVER I SAY kpart, i will be referring to QTParted because its easier) and im gonna make a new partition on it to try it again ;)
and its Single Boot , no windows crap on THIS machine ^-^
Okay now im typing everything i see
i type in "sudo knoppix-installer"
then it beeps
then it goes bloo screen and says:
INITIALISATION OF KNOPPIX-INSTALLATION
This script will install knoppix to the hard disk. Note that this version is still an very early version and under heavy development. (etc etc)
Options: OK
(next page)
The installer detected that the installation requirements are not fullfillled yet.
Please make sure that you have a free partition with at least 2 gb to instlall knoppix on.. Also we need a swap partition with at least 128 mb, if you dont have 512 mbor more. (etc etc)
Options: ok
next one
Knoppix Partition-Menu
Choose an action:
1. Partition
2. Quit
Options: ok, quit, help- Selected OK on action # 1
next screen
Partitioning harddisk for knoppix
Choose one disk:
( ) hda Quantium fireball lct 15 30 (30.0203 GB)
Options: next, quit, previous, help-- Chose: Next after bubbling in the hda
next screen
cfdisk2.11u
Disk drive: 30020272128 bytes, 30.0 GB
Heads: 240 Sectors per track: 63 Cylinders: 3877
then it lists my partitions
ive got 2, both of em i made
one is:
Name-----Flags-----Part Type-----FS Type-----Label--------Size (MB)
hda1------boot------primary-------linux ext3--knoppixroot--5240.96
hda2-----------------primary-------linux------------------------5000.98
-----------------------Pri/log------free space-------------------19771.64
WHAT DO I DO!! ARH this is where i get stucked
PostPosted: Sun Jan 23, 2005 4:32 pm
Folding Momerator
Folding Momerator
Zambini wrote:
hey blondie-
Fedora core 3
fedora core 2
Successful (kinda)
I read the side bars 1st, now I'm on the nVidia part, great article so far, nothing I could do. I have Red Hat Pro, had it installed as a dual boot at one time, was very easy to install. I also cheated & bought the disks, for some reason I had a problem downloading the files.
Have fun, don't rip your hair out.
PostPosted: Sun Jan 23, 2005 4:47 pm
blondie- which one u got?
Red Hat Enterprise Linux AS
Red Hat Enterprise Linux ES
Red Hat Enterprise Linux WS
EDIT:
KNOPPIX INSTALL WORKS!
i did the
"IGNORE_CHECK=1 sudo knoppix-installer"
and it works
PostPosted: Mon Jan 24, 2005 9:58 am
EDIT:
i did the
and it works
Did you make a linux swap partion?
Manta
PostPosted: Mon Jan 24, 2005 4:57 pm
ya i put the linux swap and the linux w3d or whatever it was
PostPosted: Mon Jan 24, 2005 6:33 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
uhh i dont know her name. ANd sorry not prs. how about ceo??? I see if i can call in if u guys have any questions.
