It is currently Thu Mar 05, 2015 9:00 am
 Post subject: volume normalizer
PostPosted: Mon Nov 09, 2009 8:27 pm
greetings all :)
Just wondering what program (if it exist) that will do a batch scanning of mp3 file and do a volume-normalize.
On winXP I use media monkey. But I duno any for linux (i use mandriva2010).
oh by the way, I was able to install winXP's TAGSCANNER (http://xdlab.ru/_ on linux using wine. I have quite a few linux-based tag scanner but this one is way better and way faster !
update:
* i found mp3gain (console command only) which sucks
* also installed winXP mp3gain (using wine) but it looks crappy
* i might try winxp Media Monkey (using wine) and see if it works !
update 2:
* just tried Media Monkey (using wine) and it works but a bit slow, since I'm using compiz fusion kde4.3.2 and such. I wish theres Media Monkey for linux :(
PostPosted: Tue Nov 10, 2009 4:37 pm
I dunno, you have the two best MM and Mp3gain. As for linux, this popped up.
http://sourceforge.net/projects/easymp3gain/
It looks like a front-end for the console of mp3gain.
PostPosted: Tue Nov 10, 2009 9:04 pm
oh thank you so much brother :)
