It is currently Thu Jan 29, 2015 5:34 pm
 Post subject: How to disable the login in Win XP.
PostPosted: Thu Jul 15, 2004 1:20 pm
I have only one user on the system and now have to login when the system starts or goes idle. It only happened after installing SP1. I read about a fix to disable it but can't remember where I read it. Any help?
PostPosted: Thu Jul 15, 2004 1:53 pm
go into user accounts in control panel and make sure that all the other accounts are deleted, and the guest account is disabled.
you could also try going into the power options properties, and in the advanced tab, uncheck "prompt for password..."
PostPosted: Thu Jul 15, 2004 11:26 pm
You could use TweakUI to automatially login (reg hack) and then make sure that you have the screen saver set not to lock the system. That should solve your problem.
