It is currently Tue Jan 27, 2015 7:54 am
 Post subject: Dual Boot Software, What are you using?
PostPosted: Wed Oct 15, 2008 7:09 am
I have WinXP installed on one hard drive...Vista 64 installed on another hard drive and I am trying to dual boot.
What are you using?
I have tried GAG http://gag.sourceforge.net/ but I am having trouble with it seeing my operating systems.
I have looked at Acronis and it doesn't see my operating systems either....I am beginning to wonder if there is something going on with my master boot records on the drives. Thing is that XP and Vista both boot fine when I just have each one plugged into the pc by it's self. [/url]
PostPosted: Wed Oct 15, 2008 7:37 am
If you install XP first and then Vista, the Vista boot loader will find both OS's automatically.
You can try inserting the Vista DVD and running the repair start up option and see if it finds XP to give you the choice during startup of which you want to boot to.
PostPosted: Wed Oct 15, 2008 2:12 pm
Team Member [Top 500]*
Things should have gone per what Lawless covered.
However, you can download and install Vista Boot Pro and set up your boot:
http://en.kioskea.net/telecharger/telec ... a-boot-pro
Ron
PostPosted: Wed Oct 15, 2008 3:01 pm
Thanks guys...I will give it a try.
PostPosted: Mon Oct 20, 2008 7:57 am
I tried the Windows Repair and that didn't work. I still can not dual boot.
I tried Vista Boot Pro and it would not see Win XP either and it came up and said that the drive that Vista is installed on is a hidden drive and may not work correctly.
I have a feeling that GAG changed my drives to hidden some how and that is why any dual boot programs I try will not see the drives.
Does anyone have any idea of how to change drives from hidden to unhidden??
Thanks.
PostPosted: Mon Oct 20, 2008 10:24 am
I'm using Grub. ;)
PostPosted: Mon Oct 20, 2008 1:20 pm
This did not work at all for me. vista didn't find xp. I downloaded easybcd (freeware).
