It is currently Mon May 04, 2015 2:29 pm
 Post subject: When is Windows XP 64-Bit Edition out?
PostPosted: Sat Jul 10, 2004 4:52 am
When is Windows XP 64-Bit Edition out? And will Athlon 64 gaming systems run it? Or will it only be for workstations?
PostPosted: Sat Jul 10, 2004 8:52 am
Chief Surgeon
Chief Surgeon
Windows XP 64-Bit is already out for Intel Itanium Workstations. It's Called Windows XP 64-Bit Version 2002:
http://www.microsoft.com/windowsxp/64bit/evaluation/faq.mspx
This is the link to Windows XP 64-Bit Extended:
http://www.microsoft.com/windowsxp/64bit/evaluation/overviews/extended.mspx
Any of the AMD Athlon64's will be running WinXP-64E
SC64
PostPosted: Sat Jul 10, 2004 3:59 pm
What's the difference between the two 64 bit Windows?
PostPosted: Sat Jul 10, 2004 4:02 pm
any CPU that has 64bit power should be able to run it
PostPosted: Sat Jul 10, 2004 6:30 pm
XP-64E contains the new instruction set AMD made.
PostPosted: Sat Jul 10, 2004 7:40 pm
So XP-64 can run on Athlon 64, but XP-64E just runs better on the Athlon 64?
PostPosted: Sat Jul 10, 2004 8:55 pm
WinXP-64 may be OEM-only...
http://arstechnica.com/news/posts/20040630-3948.html
PostPosted: Sun Jul 11, 2004 5:28 am
The Logik! Bot
The Logik! Bot
One will only run on Itanium, the other (currently in beta) will run on AMD64 and Intel's x86-64 CPUs
PostPosted: Mon Jul 12, 2004 6:27 am
Any expected date for the release of WinXP-64E?
