It is currently Fri Feb 27, 2015 7:39 am
 Post subject: Mozilla Vulnerability
PostPosted: Fri Jul 09, 2004 5:05 am
Please see links below for story and fix.
ZD Net Story:
http://zdnet.com.com/2100-1105_2-526267 ... zdnn.alert
Mozilla Fix:
http://www.mozilla.org/security/shell.html
PostPosted: Sat Jul 10, 2004 4:03 pm
thanks for the heads up
PostPosted: Mon Jul 12, 2004 7:11 am
0.9.1 sure lasted long.
PostPosted: Tue Jul 13, 2004 3:15 pm
Bitchin' Fast 3D Z8000*
This isn't all that bad....
Quote:
this flaw only allows the attacker the ability to run an existing program and requires that security problems in other applications be exploited to gain further access.
Here is a link to some commentary by the devs....
http://bugzilla.mozilla.org/show_bug.cgi?id=250180
It appears that the most likely attack would be to a non-existant file which will probably cause the computer to crash (this doesn't appear to have happened in every case).
