It is currently Tue Mar 03, 2015 1:20 am
 Post subject: Adding more sound events to WinXP?
PostPosted: Fri Oct 29, 2004 5:45 pm
Is there a way to add support for more sound/audio events in Windows XP? I would like to add additional sound events, such as when the CD tray ejects, when a screen saver prompts me for a password, when I start a virus scan, when virus scan is completed, etc. Thanks.
 Post subject: Re: Adding more sound events to WinXP?
PostPosted: Sun Oct 31, 2004 9:58 am
Every sound event is a specific event object.
I'm sure there is a script option that you could use to make new event objects and then assign them to specific events in the Registry - such as when the cd-rom opens. There's no way to do this natively in windows, unless you go through sound/audio panel and use what is there.
How comfortable are you with VB script?
PostPosted: Sun Oct 31, 2004 8:08 pm
I don't know any programming. If it's not too hard, can you make one and share it? :)
