It is currently Mon Mar 30, 2015 10:20 am
 Post subject: msconfig for Win2K?
PostPosted: Wed Jul 07, 2004 10:51 am
I know that this was available in Win98 and also in WinXP, and that for whatever reason it was not available in Win2k. How can I stop the varioous processes from running at startup in Win2K the way msconfig allows me to in WinXP?
PostPosted: Wed Jul 07, 2004 10:59 am
download X-Setup from http://www.xteq.com
there is an entry for the startup programs
or, you can go straight into the registry for it...
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
of course, be careful when mucking about in the registry, cuz there's no undo button...
PostPosted: Wed Jul 07, 2004 11:03 am
Thanks!!
PostPosted: Thu Jul 08, 2004 7:29 pm
You sir are very welcome.
 Post subject: MSConfig
PostPosted: Fri Jul 09, 2004 7:35 pm
You can copy the msconfig.exe from an XP machine to the Winnt\system32 directory and just run it normally from start, run, msconfig. It's worked fine for me on many machines with Win2K. Makes killing spyware much easier.
