It is currently Tue May 05, 2015 7:39 pm
 Post subject: Registry monitoring tool
PostPosted: Tue Oct 26, 2004 7:21 pm
Hi folks!
Could anyone recommend a good registry monitoring tool for Windows XP? Maybe something that can see all the changes made by program install and also be able to undo them completely.
Thanks in advance! :)
PostPosted: Wed Oct 27, 2004 3:10 am
Notched on both sides
Hey there are a lot of programs and lots of ways to do what you want to do...
And older app that should still work is InCtrl 3
I tend to use Filemon and Regmon from SysInternals
I take snapshots of both before an app installs and then compare the before and after... (Haven't used it in several months - but the help files are good)
Tuathal
PostPosted: Wed Oct 27, 2004 5:21 am
Thanks a lot! I will try Sysinternals :) These guys have some neat utils, I didn't know that had one for registry
PostPosted: Wed Oct 27, 2004 5:27 am
Ya its amazing how good there stuff is...
Just a note of warning - the first time someone uses regmon or filemon they are sometimes shocked at the amount of data hehe -don't worry the tool is just that good at tracking EVERYTHING... Might want to run it and play around with filtering stuff to get the most accurate info...
Tuathal
PostPosted: Wed Oct 27, 2004 5:35 am
Thanks! I'm runnig it right now. I filted to Writes or Errors only and it doesn't seem so overwelming now :)
