It is currently Fri Feb 27, 2015 6:38 pm
 Post subject: Computer Services Starting Error
PostPosted: Thu Oct 21, 2004 10:44 am
No Hope = No Fear
No Hope = No Fear
I'm using a Remote Administrator Program that installs itself as an service and all of the workstations work fine except this one, every machine was imaged off of the same image, so i know it can be a difference there...
the user account has LOCAL administrator rights and that is all that is required to run the service so i get this error message...
any suggestions?
PostPosted: Thu Oct 21, 2004 11:15 am
team psycho or sumthin
i have no idea on how to help...but i must ask.what skin are you using for XP?
PostPosted: Thu Oct 21, 2004 1:00 pm
No Hope = No Fear
No Hope = No Fear
dogmaX, along with window blinds
PostPosted: Fri Oct 22, 2004 4:55 pm
Notched on both sides
According to the makers of the software App RAdmin, here are 4 common steps that they suggest you check to ensure everything is setup properly:
1. You state that you are using the Local Admin account for the service - this is actually not advised (with most services) because if the Admin username/password changes - its possible to break the service. Instead - choose to use the Local "System Account"......
2. Make sure you are NOT using "switch user" feature.
3. On the server computer go to the Start->Settings->Control Panel -> Administrative Tools->Services. Double-click Remote Administrator service. Go to the Log On tab. Make sure "Allow service to interact with desktop" check box is checked.
4. Make sure you are using lastest video card drivers on server and client.
5. There is a Hardware Acceleration option in Windows, located at "Start->Control Panel->Display Properties -> Settings -> Advanced -> Troubleshooting->Hardware Acceleration" option which the default is FULL. Try setting it to NONE (both on client and server).
6. Make sure you are running RAdmin 2.1 - 1.1 doesn't work on Win2k / XP.
7. Ensure that the port you have the service setup to connect to and through is available - if it can't access the port - the service will shut down.
8. Try removing it and then installing it as an application (just to see if it works then...).
9. go to r_server /setup -> click "Options" Enable the Log file and then look at the log file for more info. If the log file is enabled - See if it can give us any details as to why its happening. Also check the System and Application Event logs for more info for us.
Thats about all I have - if none of this helps - give us some info from the log files. :)
Hasta,
Tuathal
PostPosted: Mon Oct 25, 2004 7:59 am
No Hope = No Fear
No Hope = No Fear
I actually was able to fix the service, by removing all of my users.. and the re-adding them... apparently one of the users was deleted from the system and was causing the service "not" to authenticate and stop...
close enough, it got me in the right direction...
-thnx-
PostPosted: Mon Oct 25, 2004 11:02 am
hehe
Dang
Once again I should learn to stop at my gut thought :P
Tuathal
