It is currently Mon Apr 20, 2015 9:29 pm
 Post subject: help finding a prog listed in mag
PostPosted: Tue Oct 19, 2004 6:33 am
I KNOW I read in a past issue of my fav mag, that ther was a program that went thru all of the processes listed in XP( cntl , Alt, Del ) and identified exactly what each process was doing and where it came from. I had ment to go get this program several times but kept the mag in my " thinking area" , hehe.
well now I was determined to go get the issue and after flipping cover to cover thru about 10 issues from NOV back, I am stil unable to locate this program.
I know you guys digest these issues like I do, and know what im talking about.
I wanna say it was very close to the front sections of the mag, but again, since I 've looked there, I cant be sure.
any help is greatly welcomed. thanks in advance.
PostPosted: Tue Oct 19, 2004 6:32 pm
Notched on both sides
Well, I'm having trouble finding my issue with the 10 best utils you've never heard of, but in my other issues - I only saw a section on using MSCONFIG to look at the services being loaded... That util is included with Windows so I'm guessing thats not it :)
Try checking out this site:
http://www.majorgeeks.com/download4313.html
Its for a freeware App called "Service Controller XP".
It says its "a tool designed to control and get detailed information about the services running on your computer".
I've installed it to my test machine and have not seen any spyware/adware in it (from Ad Aware Pro or Spyware Blaster) and it did not contain any viruses according to AVG and eTrust....
Hope it helps!
Cheers,
Tuathal
Are you Folding for a cure? Why not? Its easy, free, and doesn't hurt anyone - in fact it can only help![/url]
PostPosted: Wed Oct 20, 2004 5:45 am
thanks for a quick reply.
however, I think that the Services, and the Processes are two different things.
I will look at the program you suggested though, and thank you for your reply.
PostPosted: Wed Oct 20, 2004 7:54 am
Aye I heartily agree - but it was the closest thing I found in the mag hehe
Tuathal
PostPosted: Wed Oct 20, 2004 11:55 am
I don't know if it's in the mag, but here is a link to what you may be looking for:
http://www.sysinternals.com/ntw2k/freeware/procexp.shtml
PostPosted: Wed Oct 20, 2004 12:37 pm
procexp is a very nice program.
PostPosted: Thu Oct 21, 2004 4:04 pm
I found the following program through some online searching,
Process Viewer for Windows
It appears to be simpiler than the other program mentioned in this thread [which I haven't tried yet] but does the job of displaying a more detailed listing of the processes running on your system and their resources.
Sully
PostPosted: Sat Oct 23, 2004 8:23 am
hehe ProcessXP - you know - as often as I check out that website - you'd think I would have thought to just go there first...
Oh well.. Call it a non-geek moment... :shock:
Tuathal
