It is currently Sun Jan 25, 2015 8:42 am
 Post subject: location of documents and settings folder
PostPosted: Mon Oct 18, 2004 9:11 pm
is their's any one who knows how to change the drive location of the
documents and settings folder. or at least the shared docs. and user doc. folders, if you do please let me know.
 Post subject: Re: location of documents and settings folder
PostPosted: Tue Oct 19, 2004 7:03 pm
Notched on both sides
Yup,
Check out the following article from Microsoft:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q322014&
Note if you don't need to change the default location (like for XP Setup) and just want to change the existing location on a machine that has Win2k or WinXP - You can change the location of these profile directories in the following location in the Registry
Hive: HKEY_LOCAL_MACHINE
Key: Software\Microsoft\Windows NT\CurrentVersion\ProfileList
Data Type: REG_EXPAND_SZ
Value: path
Make sure that you backup your registry and the profiles before making any changes. Also note that this will only take effect for users who log in AFTER the change has been made.
Lastly - you'll have to copy the Default user Profile to the new location in order to ensure that new users work properly as that profile will not be moved when the users log on...
Hope it helps - let me know how it turns out!
You can normally find me in the folding forum :)
Cheers,
Tuathal
Are you Folding for a cure? Why not? Its easy, free, and doesn't hurt anyone - in fact it can only help!
