It is currently Mon Jan 26, 2015 2:25 am
 Post subject: sLOW PC
PostPosted: Fri Oct 15, 2004 9:49 am
:twisted: Hello Players
I am having problems with my pc. XP sp 2 loads up slow and takes forever to work. I will click on an icon and it takes up to 30 seconds. I thought it was my video card, I changed it, but problem persists. At boot up I get a mesage about detecting RAID 0 and Raid 1, this takes a while too. Please help
System
SOyo KT 600 Ultra Plat.
amd 2500 barton
1 gb pc 2700
80 gb WD 8mb Cache
Nvidia 5200 video card w/256 mb
Mouse
Monitor
Keyboard
Speakers :) :? :lol:
PostPosted: Fri Oct 15, 2004 10:02 am
Professional Dork
Professional Dork
Is this a fresh install?
If not, run adaware/spybot and hijackthis to get rid of any potential spyware/malware on the system.
Other things to look for:
  • Make sure your hard drive is set to the correct speed in the BIOS. If it's an ATA100 drive, make sure the BIOS knows your Primary IDE is that speed.
  • Make sure you have the latest Via 4 in 1 drivers.
  • Make sure you're not running anything at startup.
PostPosted: Sat Oct 16, 2004 7:25 am
could be sp2 as well. people had slow bootup problems when they installed sp2.
 Post subject: Re: sLOW PC
PostPosted: Tue Oct 19, 2004 7:32 pm
Notched on both sides
System
amd 2500 barton
1 gb pc 2700
80 gb WD 8mb Cache
Mouse
Monitor
Keyboard
Aside from the fact that I'm running 1.5GB of RAM and have a GeForce FX5950, you have described my problem with SP2 entirely.
I performed a complete CLEAN install - and the problem occurred as SOON as I put SP2 on - no other apps installed, just necessary drivers and Windows updates.
Then I stole my wife's Asus MB and stuck that in there (its an A7V600). Put the mb in my case with all of my perifs, cpu, mem, etc.. and once again performed a clean install.
No Slow down.
There is something on that Soyo board that SP2 just DOES NOT LIKE...
NOTE: Had the same problem with my Shuttle board.. But that doesn't surprise me as I believe the Model number for that board was P.O.S....
:lol:
Cheers,
Tuathal
Are you Folding for a cure? Why not? Its easy, free, and doesn't hurt anyone - in fact it can only help!
I found it to be the Board. (I switched out to an ASUS board -
