It is currently Mon May 04, 2015 1:23 pm
 Post subject: XP - Computer Name/Description
PostPosted: Tue Jul 06, 2004 4:10 am
Running XP Home w/ SP1. At some point in building my new system I must have been prompted to enter a name and or a description of the system that appears in the lower left hand corner when Win first boots up at the user log in screen. Where are the settings to change these?
 Post subject: Re: XP - Computer Name/Description
PostPosted: Tue Jul 06, 2004 4:17 am
Professional Dork
Professional Dork
Right click on "My Computer" and select Properties. Go to the "Computer Name" tab and you can enter, change, or remove the description. Click on the "Change" button and you can change your computer's name.
PostPosted: Tue Jul 06, 2004 7:32 am
Thanks :!:
