It is currently Mon Apr 20, 2015 9:22 pm
 Post subject: Easy language switching in Word?
PostPosted: Tue Oct 12, 2004 1:54 pm
I do a lot of writing in Spanish as well as English and find it annoying to keep setting Spanish as the default language then switch it back to English to do an English file. I tried to just choose Spanish for individual files under Tools/Language/Set Language but Word (Office XP) doesn't apply Spanish unless I set it as a default. Since this is an annoyance issue, I figured I should post it here.
Is there a way to set languages for individual files?
PostPosted: Tue Oct 12, 2004 3:04 pm
Team Member Top 100
Team Member Top 100
I don't know if you can set individual files or not. You can however, set up a key sequence that will flip between languages though.
Go to regional and language options in the control panel, languages tab, details, key settings. You should be able to enter a hotkey sequence to switch between Spanish/English input.
Hope that helps.
PostPosted: Tue Oct 19, 2004 7:21 pm
Notched on both sides
Hope that helps.
Yup I agree completely with that, but you'll still have to also set the language in Word if you want the proofing tools to work.
I would create a simple macro that does the following actions in a file you want set for Spanish
Select All
Tools, Language, Set Language (Depending on your version)
Choosing Spanish
You could record that macro and assign it to a toolbar button for easy access (or give it a shortcut key as well).
Cheers,
Tuathal
Are you Folding for a cure? Why not? Its easy, free, and doesn't hurt anyone - in fact it can only help!
