It is currently Wed Jan 28, 2015 11:22 pm
 Post subject: Msconfig Error
PostPosted: Sun Oct 10, 2004 9:47 pm
When i type "msconfig" in run i get this error message (please help if you can)
"Windows cannot find 'msconfig'. Mkae sure you typed the name correctly, and then try again."
PostPosted: Sun Oct 10, 2004 10:38 pm
Team Member Top 100
Team Member Top 100
a little more information would be helpful
PostPosted: Mon Oct 11, 2004 3:04 am
team psycho or sumthin
C:\WINDOWS\pchealth\helpctr\binaries
look to make sure it is still there...."msconfig.exe"
(this if for XP)
PostPosted: Mon Oct 11, 2004 5:04 am
You can also type the following in a DOS window.
C:\dir msconfig*.* /s /w
This will show you where it is located if it's still on you hard drive.
PostPosted: Mon Oct 11, 2004 12:45 pm
hey ninja if you are using win2000 as your o/s then you dont have msconfig. on the other hand, if you are using winxp and even win98, then all is fair game.
PostPosted: Tue Oct 12, 2004 7:27 am
If you are in Win2000 then I would get a copy of msconfig.exe from another PC with XP and copy it to the system32 dir in your windows or winnt dir. The msconfig from XP works just fine in win2000. I'd like to know who decided to leave it out of that OS anyway.
