It is currently Thu Mar 05, 2015 12:59 am
 Post subject: best mem optimizer utility
PostPosted: Fri Oct 08, 2004 1:28 am
i have been surfing around for a good mem. optimizer utility.
but cant seem to find one that i am trully comfortable with,
sow if anyone knoledgable enough out there or at maximum pc can recomend one that i should use or try
PostPosted: Fri Oct 08, 2004 2:24 am
Celeron
Celeron
the only way to "optimize" memory is by shutting off tasks that require lots of memory. Memory optimizers dont work, trust me.
PostPosted: Fri Oct 08, 2004 5:20 am
Team Member Top 100
Team Member Top 100
What he said. The only exceptions I would make are a couple of the old progams that were designed to free up memory in the 9x versions.
 Post subject: optimize mem. utility
PostPosted: Fri Oct 08, 2004 5:25 am
thanks for the feedback
No Hope = No Fear
No Hope = No Fear
You could try this little program...
PostPosted: Fri Oct 08, 2004 11:12 am
cacheman worked well when I used it. However it should be noted that after a few runs if you kept trying it would start moving ram to paging file, and it never quiet explained that so for all I know it may do that EVERY time you hit the "free up ram" button.
if you're running windows xp you shouldnt need one. Just reboot every once in awhile and dont run to much crap.
 Post subject: best mem optimizer utillity
PostPosted: Sat Oct 09, 2004 8:07 am
thanks for your comment cacheman
