It is currently Mon Mar 02, 2015 11:50 am
 Post subject: Norton Partition Magic 8.0
PostPosted: Sun Oct 03, 2004 2:55 pm
Anyone use Norton Partition Magic 8.0? I'm interested in the pros and cons.
PostPosted: Tue Oct 05, 2004 4:13 pm
I've used it what you want to know?
PostPosted: Tue Oct 05, 2004 4:17 pm
What are the advantages to partitioning drives? How easy is it to use? If I partition my c drive into two partitions, do I just put Windows on one and everything (drivers, downloads, programs, etc.) on the other?
PostPosted: Tue Oct 05, 2004 4:27 pm
Norton Partition Magic is basically the same as Partition Magic, they were just bought out by Norton. The advantages of partitioning a drive are that you can make one partition for your os and another for files and data. That way if you ever have to do a clean install you don't lose your data. Using Norton Partition Magic is really easy and yes you can install Windows on one and programs on another. If you look in the forms alittle more there is a thread about the advantages/disadvantages about partitioning.
PostPosted: Tue Oct 05, 2004 4:29 pm
http://www.maximumpc.com/forum/viewtopic.php?t=4080
heres the link to the other thread look alittle ways down for what dexter has to say.
