It is currently Wed Mar 04, 2015 1:14 pm
 Post subject: trouble formating C drive
PostPosted: Sat Oct 02, 2004 12:34 pm
This is an old Win98 system. Made boot disk, when start from that I get 3 choices:
1 Start computer with cd-dom support
2 start without cd-rom support
3 view help
Choosing either of the first two brings me to a command prompt. I type in
format C: /s as the help file directs me to. It gives me a warning about erasing data. Then it starts to check for bad sectors, gets to 6% and then stops and tells me that I have insufficient memory. There is 192 Mb of Ram and the 4 Gb hard drive has 1 Gb empty.
How can I format?
PostPosted: Sat Oct 02, 2004 2:30 pm
Team Member Top 100
Team Member Top 100
Did you run
FDISK
before you tried to format c:?
PostPosted: Sat Oct 02, 2004 4:18 pm
Don't remember formating ever checking for bad sectors unless you specify that..and it sounds like you're not.
You sure you're not leaving a step out in there??
That is something that fdisk would do though.
Exactly where did you get this bootdisk from??
PostPosted: Sat Oct 02, 2004 5:00 pm
Folding Momerator
Folding Momerator
Here are some instructions for Fdisk and a link to Bootdisk.com
