It is currently Thu Jan 29, 2015 7:32 am
 Post subject: Perfect Disk versus Diskkeeper Pro
PostPosted: Thu Sep 30, 2004 4:50 pm
Any opinions on Perfect Disk versus Diskkeeper Pro?
PostPosted: Thu Sep 30, 2004 5:10 pm
ive never used perfect disk but i gotta tell you that diskeeper pro is very good.
PostPosted: Wed Oct 06, 2004 6:36 pm
Perfect disk has spyware added into it!! I personally use Diskeeper, and love it!
Malossi
PostPosted: Thu Oct 07, 2004 9:19 am
Team Member Top 100
Team Member Top 100
I've been using Diskeeper pro and it's been great. Don't know much about Perfect Disk
PostPosted: Thu Oct 07, 2004 5:32 pm
I've never heard of Perfect Disc, but I can tell you from experience that Diskeeper Pro is a great program. It keeps my drives fast. I highly recommend it. :D
PostPosted: Thu Oct 07, 2004 10:51 pm
Add me to the "Love disk keeper, never heard of this perfect disk" party.
PostPosted: Tue Oct 12, 2004 6:07 pm
I use diskeeper also. Great program. I think newer version (9.0) is around the corner.
What's perfect disk, by the way? :roll:
PostPosted: Wed Oct 13, 2004 3:07 pm
Perfect Disk is a defragging software.
 Post subject: Both are good
PostPosted: Wed Oct 13, 2004 7:46 pm
both are good they do, do the same thing there better than microsofts defrag program in windows, perfect disk is easy 2 use and diskkeeper pro is easier 2 use. I would go with diskkeeper. Is it diskeeper or diskkeeper spelling wise.
PostPosted: Thu Oct 14, 2004 5:16 pm
Here's the poop on PerfectDisk 6.0. I started using Diskkeeper first and then switched to PerfectDisk and have been using it for about two years. I really have nothing against Diskkeeper; just like PerfectDisk a little better. Just one thing, and this may be a little lame but I felt that Diskkeeper defragged too quickly to do a thorough job.
PostPosted: Fri Oct 15, 2004 5:30 am
Team Member Top 100
Team Member Top 100
Diskeeper.
Then the defrag utility in Win98 must be the best one out, it's the slowest one I've ever used. :P
PostPosted: Fri Oct 15, 2004 5:45 am
Contributing Writer
Contributing Writer
It's funny how two people can look at the same thing, yet see something completely different. Diskeeper's speed has always been a 'plus' for me.
FYI for anyone interested - the included defragmenter in Windows XP is basically a very lite and limited version of Diskeeper. Executive Software developed both:
MS Link
PostPosted: Sat Oct 16, 2004 7:51 am
Yup, version 9.0 of Diskeeper has been released. It has some very good improvements. I've been using it for aound 1 week now, and its great.
Marco
PostPosted: Sat Oct 16, 2004 8:57 am
What is the difference between Diskeeper 8 Home Edition and Diskeeper 9 Home Edition?
PostPosted: Sat Oct 16, 2004 11:10 am
Team Member Top 100
Team Member Top 100
The changes are here. They added a couple features, improved the engine, and added some scheduling options.
 Post subject: Re: Perfect Disk versus Diskkeeper Pro
PostPosted: Tue Oct 19, 2004 9:18 am
Right now, I'm definitely (note that it is spelled correctly) leaning towards Perfect disk. I've used it quite a few times and to me, it seems to do a better job.
Plus, at work we have Diskeeper 5.0. server. It says on the box that it's 2000 compatible, however when I try to install it, it says it's not compatible.
So, I download the latest update and try that. Same thing.
So, fuck diskeeper.
PostPosted: Wed Oct 27, 2004 1:43 am
Raxco Software PerfectDisk V6 just got a pretty good review from Redmondmag.com - This application has some cool features that Diskeeper V8 lacks. Here's just a few.
- Windows Certification - application meets all Microsoft criteria for driver compliance, while Diskeeper V8.0 is not certified
- Smart Placement Defrag - arranges free space in contiguous blocks & optimizes your files based on the frequency with which they are accessed. This helps reduce wear and tear and hopefully prolonging the life of the drive. Diskeeper uses a random placement strategy.
- Free Space Requirement - PerfectDisk requires a minimum of 5% available free space while Diskeeper suggests a minimum of 20% free space.
For more information, read the White Paper titled Unique Differences Between PerfectDisk V6 and Diskeeper V8 on their website here
-misterLOBY
PostPosted: Wed Oct 27, 2004 2:45 am
Notched on both sides
Nice info ML,
I will point out one difference however..
I run Diskeeper 8 Pro and Server and in both versions there is an option to have it watch your program activity for more efficient and smart defragging...
According to what I've seen - thats their version of Smart placement.
Just FYI
Tuathal
