It is currently Fri Feb 27, 2015 9:40 pm
 Post subject: Windows XP 64 Bit
PostPosted: Tue Sep 28, 2004 7:03 am
No Hope = No Fear
No Hope = No Fear
UT2004 has the 64 bit version released so whats the hold up on the OS???
64 bit demo downloads available Here
PostPosted: Tue Sep 28, 2004 9:14 am
Good question!
Coding a 64-bit OS can't be half as complicated as porting a 32-bit game to a 64-bit environment.
:roll:
PostPosted: Tue Sep 28, 2004 9:17 am
Porting the game would be relatively simple, basically just a new command line option when they compile it. Especially since Athlon64's can run 32bit programs without issue. It's not like the game has to do anything different to run. The OS on the otherhand has to act as the interface between the hardware and the software, as such there is more involved. Last I heard XP64 will be first quarter of 05.
PostPosted: Tue Sep 28, 2004 10:22 am
Any advantages of running win64 now? Or should I just keep XP runnin till it gets more support?
PostPosted: Tue Sep 28, 2004 12:13 pm
Team Member Top 100
Team Member Top 100
There are two problems with running Win 64 now.
1. It's still BETA software.
2. Driver support is still sketchy.
There really aren't that many apps that take advantage of it yet, so unless you just feel like being a guinea pig, I don't think it's worth the headaches. Keeping in mind that it's still BETA, I wouldn't advise putting it on a primary or sole system.
PostPosted: Tue Sep 28, 2004 4:43 pm
Color me stupid here, but where are you seeing that's 64 bit specific from that link?
PostPosted: Tue Sep 28, 2004 4:44 pm
I was thinkin' the exact same thing. I have it on CD, but I'm gonna stay away from it right now.
