It is currently Sun Mar 29, 2015 8:37 pm
 Post subject: ERROE REPORTING ON EVERY PROGRAME I USE
PostPosted: Sat Sep 25, 2004 6:54 pm
I HAVE BEEN GETTING THES ERROE REPORTING MESSAGES EVERY TIME I OPEN A PROGRAME LIKE WHEN I TURN ON THE COMPUTER AND GO TO MY DESKTOP A MESSAGE FROM WINDOWS POP UP SAYS SEND OR DONT SEND AND I SAYS THAT TO EVERY PROGRAME I USES AND I TRYED TO INSTALL WINDOWS AGINE AND IT DID THE SAME THING
PostPosted: Sun Sep 26, 2004 2:14 pm
Folding Momerator
Folding Momerator
What does the error say? Is it an illegal operation? When given the option to send, click yes. This will bring up a message about what to do.
 Post subject: Re: ERROE REPORTING ON EVERY PROGRAME I USE
PostPosted: Sun Sep 26, 2004 5:51 pm
Looks like you also have a problem with your Caps Lock key. :P
When you send the error reporting it should give you a website to goto to say what that error was and what caused it. What does it say, if anything?
What does your event log say the errors are?
Get to your event log by going to Start/Control Panel/Administrative Tools/Event Viewer. Look at applications.
Post your system specs, service packs (SP1 or SP2) and applications you have installed also.
Dave
PostPosted: Mon Sep 27, 2004 5:20 pm
kk i foune like 760 errors and i here they are
Access denied attempting to launch a DCOM Server using DefaultLaunchPermssion. The server is:
{00020906-0000-0000-C000-000000000046}
The user is Unavailable/Unavailable, SID=Unavailable.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
The IMAPI CD-Burning COM Service service entered the stopped state.
The IMAPI CD-Burning COM Service service was successfully sent a start control.
The time service has not been able to synchronize the system time for 49152 seconds because none of the time providers has been able to provide a usable time stamp. The system clock is unsynchronized.
Error code 00000050, parameter1 a1fc7918, parameter2 00000000, parameter3 80590323, parameter4 00000000.
The NIC Management Service Configuration Driver service was successfully sent a start control.
The Remote Access Auto Connection Manager service was successfully sent a start control.
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000050 (0xa1fc7918, 0x00000000, 0x80590323, 0x00000000). A dump was saved in: C:\WINDOWS\Minidump\Mini092504-01.dmp.
Microsoft (R) Windows (R) 5.01. 2600 Uniprocessor Free.
The browser has forced an election on network \Device\NetBT_Tcpip_{5A5BC4CA-2CDC-4646-8FBA-044B580444BB} because a master browser was stopped.
Application popup: wmplayer.exe - Application Error : The instruction at "0x77f82e51" referenced memory at "0x00120005". The memory could not be "written".
Click on OK to terminate the program
Faulting application iexplore.exe, version 6.0.2600.0, faulting module mshtml.dll, version 6.0.2600.0, fault address 0x00131b43.
PostPosted: Tue Sep 28, 2004 2:57 am
team psycho or sumthin
sounds like it is time for a windows reinstall
PostPosted: Tue Sep 28, 2004 4:25 am
Folding Momerator
Folding Momerator
Is this a name brand computer or one you built? Either way, please post the specs (brand, model number)
PostPosted: Tue Sep 28, 2004 9:16 am
Reformat and reinstall ... your OS is borked.
PostPosted: Tue Sep 28, 2004 10:23 am
that is a lot of freakin errors... I agree with everyone else, reformat and reinstall man.
PostPosted: Tue Sep 28, 2004 11:58 am
Folding Momerator
Folding Momerator
Yeah, I agree, but
According to that, he's tried it already.
PostPosted: Tue Sep 28, 2004 3:50 pm
i try to reistall windows it did the ysame thing kkk her is what i have in my comp
1G pc3200 of ram
p4 3.0e
abit ic7 max3
a dvd
a chaintech sounde card 7.1
i have a compro pvr
chaintech fx5200 256 md graphic card
i think the problem started when i ordered new parts to put in my comp like the pvr and the sounde card and the dvd
PostPosted: Thu Sep 30, 2004 5:06 pm
Folding Momerator
Folding Momerator
I'd have to say that I would take out the sound card (don't know what a pvr is) get into your BIOS and default everything. After you do that, put your XP CD in and make sure you format the hard drive. Today I ran into some weird things on hubby's puter. I tried to do the regular format, it wouldn't let me. I had a bunch of files that for some reason wouldn't copy. I ended up doing a quick format- no problems after that. Once you get it running, without erros, then add the sound card after disabling the onboard sound.
PostPosted: Sat Oct 02, 2004 6:56 am
i did what u tolled me and it worked for now now errors till now
thanxs people for who helped me
PostPosted: Sat Oct 02, 2004 4:50 pm
Folding Momerator
Folding Momerator
Great :!: :D
