It is currently Fri Mar 27, 2015 5:26 am
 Post subject: Maxtor 200g install Fat 32
PostPosted: Fri Sep 24, 2004 4:37 pm
I've installed a Maxtor 200Gb disk in a casing and connected it to the puter with USB cable.
On a separate USB 2.0 card.
Partitioned it with Acronis PartitionExpert.
WARNING, ALL DATA ON NON-REMOVABL
DRIVE M: WILL BE LOST!
Proceed with Format (Y/N)? y
Verifying 194474M
The volume is too big for FAT32.
Devided it into 2 partitions and formatted one with the below result.
C:\>format L:
The type of the file system is FAT32.
WARNING, ALL DATA ON NON-REMOVABLE DISK
DRIVE L: WILL BE LOST!
Verifying 102437M
Question:
How or what do I use to format the USB dive?
Can I or can't I use one big partition with FAT32?
Win2k is the O/S & because win98 shall be able to communicate properly with the other OS's in the network
PostPosted: Sat Sep 25, 2004 6:48 am
I'm not sure you'll be able to partition something that big.
I beleive you'll have to create a smaller partition and then expend the partition with something else.
Have you tried to use the disk that came with the Drive instead of acronis??
and on a different note...I'm not sure why you're formating this as such with concerns for networked machines. 98 with see a NTFS share just fine
 Post subject: Re: Maxtor 200g install Fat 32
PostPosted: Sat Sep 25, 2004 9:50 am
I'd rather be modding!
Question:
You will have to divide it into about 7 partitions to get them small enough for FAT32. Standard FAT32 has a limit of 32GB partition sizes.
Like said above, Win 98 can see NTFS files on a share drive. You are not networking the drive, you are networking the system. Confirm that to be sure.
NTFS can format up to a 2TB partition
EDIT - I failed to mention that 2TB is "in theory". The OS using it or other hardware issues may limit this as well. END EDIT
Manta
