It is currently Thu Mar 05, 2015 12:13 am
 Post subject: Shutting off messenger !?!?!
PostPosted: Fri Sep 24, 2004 3:01 am
I have uninstalled Microsoft Messenger in the Remove Programs section. I have unchecked the box in Outlook to start Messenger when Outlook starts. However, when I open Outlook, Messenger still appears down in the bar next to the clock. When I close Outllok it stays there. I have to manually close it.
Does anyone have a way to permenantly remove this bothersome program so that it will not run at all?
Thanks in advance for any help. BTW, XP Home is the OS.
:D
PostPosted: Fri Sep 24, 2004 4:02 am
http://grc.com/stm/shootthemessenger.htm
This will let you get rid of that little bugger.
PostPosted: Fri Sep 24, 2004 4:03 am
Million Club
Million Club
While I'm not sure exactly how Messenger works, despite uninstalling it from the programs list in the Control Panel as well as trying to disable it manually will still keep it somewhat active in Windows as it was designed to be an intergrated part with the operating system.
However... there is a solution.
Shoot The Messenger
This small little program works a miracle - it completely disables the messenger service from Windows. You'll literally never see it again! The program itself takes about a minute to work, so if you don't see anything respond right away after executing it, don't worry - your system isn't frozen.
Just use it once and you'll never see that damned messenger tray icon again!
:D
PostPosted: Fri Sep 24, 2004 4:04 am
Million Club
Million Club
*grumbles at Jokers, posting a few mere seconds before he did...* :P
PostPosted: Fri Sep 24, 2004 4:34 am
Didn't help!!
As soon as I open Outlook Express, the Messenger Icon appears down by the clock. I have to manually exit out of it, even though it isn't signed in, or it stays there.
Any more suggestions? (not sarcasm)
Thanks to those who answered, and those who will.
PostPosted: Fri Sep 24, 2004 4:59 am
Open it up, find the Preferences page, and uncheck the options that allow it to start.
PostPosted: Fri Sep 24, 2004 5:09 am
Do you have both Windows Messenger AND MSN Messenger installed? Maybe you indeed uninstalled Windows Messenger but it's MSN Messenger that's popping up?
PostPosted: Fri Sep 24, 2004 5:51 am
Says "Windows Messenger - Not Signed In"
PostPosted: Fri Sep 24, 2004 8:01 am
Doubleclick the icon in the system tray to start it up. Find the preferences, and in there are a couple of checkboxes that allow it to start. Uncheck them, and it will go away.
PostPosted: Fri Sep 24, 2004 10:27 am
team psycho or sumthin
go to C:\WINDOWS\inf open sysoc.inf and remove the "hide" tags
ie:change-
msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,hide,7
to-
msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,,7
then you can use add/remove windows componets to remove messenger
PostPosted: Fri Sep 24, 2004 11:39 am
RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove
there's a space between INFSection and %windir%
type that in your Start -> Run, and run it.
PostPosted: Fri Sep 24, 2004 12:59 pm
Thanks for all the help !
:D
PostPosted: Fri Sep 24, 2004 5:34 pm
Ok, so have you been successful, and if so, by which method?
Simply unchecking the options to start within Messenger has always worked for me, so I'm curious as to what would require someone to go through some of the more arcane steps listed above.
Don't get me wrong, I'm not doubting the veracity or helpfulness of the other suggestions, however, without knowing more, it feels like they shot at the squirrel with a howizter, when the .22 would have sufficed. :)
PostPosted: Sat Sep 25, 2004 3:22 am
I had the same proble. Very annoying! I searched google, and I found this site: http://www.dougknox.com/xp/tips/xp_messenger_remove.htm
It works great, for some reason I couldn't download the file, but by following his instructions, its easy. Follow the steps I have written (from the site).
To remove Windows Messenger manually, click Start, Run and enter the following command:
RunDll32 advpack.dll,LaunchINFSection %windir%\inf\msmsgs.inf,BLC.Remove
Note: This will prevent a long delay when opening Outlook Express if you have the Contacts pane enabled. To prevent this, click Start, Run and enter REGEDIT Go to:
HKEY_LOCAL_MACHINE\Software\Microsoft\Outlook Express
Right click in the right pane and select New, Dword value. Give it the name Hide Messenger Double click this new entry and set the value to 2.
I hope this works, it did for me.
Marco
PostPosted: Sun Sep 26, 2004 5:52 am
That's not MSN Messenger...that's the internal windows messenger.
The easiest way to disable it is go to START - RUN and type SERVICES.MSC
Look for the messenger service, stop it, and disable it.
PostPosted: Sun Sep 26, 2004 6:06 am
I posted this exact same problem on the old delphi forum, but never got this kind of help :)
Until now, i just disallowed windows messenger from running in the background, so whenever i started OE and windows messenger started automatically, it would close itself immediately.
But now i have a real solution. Thanks guys. :D
PostPosted: Sun Sep 26, 2004 7:29 am
After I had everything turned off, uninstalled and what not, my son put AIM back on the comp and set all the preferences. VOILA, no more windows messenger anywhere. Not even when Outlook opens.
:D
PostPosted: Sun Sep 26, 2004 1:43 pm
Folding Momerator
Folding Momerator
I've also found that telling your firewall not to allow it to access the internet will kill it pretty quick.
Those of you with this problem, is your passport associated with your user account? If so, this could be why it is starting also. Control panel, user accounts, click on your user name, then you should see something to edit your passport. I think that was how I stopped it last time, deleted the passport info.
