It is currently Thu Jan 29, 2015 11:00 pm
 Post subject: Windows Explorer start in C:\ ?
PostPosted: Sat Sep 18, 2004 2:45 am
How can I get Windows Explorer XP to start in "C:\" drive instead of "My Computer"? Thanks.
PostPosted: Sat Sep 18, 2004 4:06 am
Contributing Writer
Contributing Writer
1) Right click Explorer
2) Select Properties
3) In the target box, replace text with:
%SystemRoot%\explorer.exe /n, /e, c:\
4) Serve warm and enjoy
PostPosted: Sat Sep 18, 2004 4:22 am
team psycho or sumthin
that almost sounds sick....but i am a pervert :D
PostPosted: Sun Sep 19, 2004 1:46 pm
another thing you can do is create a shortcut to your hard drive and then drag that to your quick launch toolbar
PostPosted: Mon Sep 20, 2004 4:58 am
There is also a "Start In" field in the properties that you simple could put in "C:\".
PostPosted: Mon Sep 20, 2004 6:12 am
Different Windows Explorer question:
Is there some way to revert to the 98-style Find dialog box? The "Explorer Bar" Find that XP defaults to is really annoying.
PostPosted: Sun Sep 26, 2004 2:34 pm
Folding Momerator
Folding Momerator
Thanks, I was getting sick of looking at My Documents opening every time I used WE.
PostPosted: Sun Sep 26, 2004 3:18 pm
Contributing Writer
Contributing Writer
No problem. And if by chance you haven't figured it out already, I'll state the obvious and mention that you can add to "c:\" to have it open wherever your heart desires. For example:
%SystemRoot%\explorer.exe /n, /e, c:\TopSecret\Honeymoon\Hotel\XXX
8)
