It is currently Wed Apr 01, 2015 6:12 am
 Post subject: 3rd install of XP, now I need a new key?!?!?
PostPosted: Wed Sep 15, 2004 1:40 pm
This could go into the SP2 after effects thread, but I didn't want this to end up being a thread-jacking.
I tried to install SP2 twice, and both times after the reboot, XP would hang on the progress screen. After the first time I did a repair install, but that left some strange glitches, so after the second try, I just backed up all my stuff and did a complete reformat. Well, after that, Windows wouldn't let me use my key anymore. It was only the third time I had used it (and it's a legal copy), so I get the pop-up window that tells me to call Microsoft to get another key.
So, the question is, has anyone ever had to actually call to get another key for a CD they've actually bought and *not* pirated, and if so, was Microsoft at least cool about it? This wouldn't have even been a problem if I hadn't tried to do the simple SP2 update. Stupid Microsoft.... :P
 Post subject: Re: 3rd install of XP, now I need a new key?!?!?
PostPosted: Wed Sep 15, 2004 1:48 pm
have you had any hardware change since the last time you entered your key/
yes, i've had to call m$ for reactivation on a key that i bought. just told them the old motherboard needed to be RMA'd and they gave me a new activation code.
PostPosted: Wed Sep 15, 2004 1:52 pm
I didn't change any of the hardware, just 3 installations.
I'll give them a call after work and see what's what.
PostPosted: Wed Sep 15, 2004 2:45 pm
I don't think they're going to offer you a new key, but rather reset the number of repairs on the key so it activates again.
PostPosted: Thu Sep 16, 2004 8:15 am
Which is exactly what happened. It actually went pretty quickly. Not too long on hold, the lady I talked to was coherent, all in all, not a bad experience. Still wish I could use SP2 kinda.... but I guess it isn't a big deal.
PostPosted: Thu Sep 16, 2004 12:09 pm
since you're already looking at a new install, i'd suggest you try slipstreaming SP2 and see if that works.
PostPosted: Fri Sep 17, 2004 10:40 am
Actually, I believe my problem was that I've got a Prescott, and MS just released a patch that addresses the problem. Appearantly, it has something to do with the BIOS... but it's supposed to fix my problem.
Actually, I only think Ive got a Prescott.... it's a P4 3.0E. NewEgg.com said it was a Prescott when I ordered it, but I didn't see that written anywhere on the box. Do any of you guys know for sure? I can give you more numbers if you need them.
Oh, and that patch is here, if anyone else is interested:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9b99c199-5d75-454f-ae07-b620727be8d8&DisplayLang=en
PostPosted: Fri Sep 17, 2004 10:42 am
Contributing Writer
Contributing Writer
Yes, you have a Prescott.
