It is currently Sun Apr 26, 2015 5:20 pm
 Post subject: Question about IP
PostPosted: Fri Sep 10, 2004 9:15 am
Does anyone know how to NOT let others see my IP address and ISP?
I really hate others spying on me... This is cause' I always am getting spyware from the same places.
 Post subject: Re: Question about IP
PostPosted: Fri Sep 10, 2004 9:24 am
firewall?
PostPosted: Fri Sep 10, 2004 10:32 am
In the lab!
In the lab!
1) the only way to hid your ip and isp is to use a proxy server...
2) hiding your ip addy and isp won't stop you from getting spyware.
Lets play a little game... remember when you were a little kid. You mommy said "don't touch the stove or you'll get burned." What was the first thing you did? You touched the stove and got burned! But you learned not to touch it again didn't you.
If you keep getting spyware you need to stop doing whatever it is that you do in the first place. Hiding your IP address is like using your left hand to touch the burner instead of your right hand. It may be a different hand but the outcome is still going to be the same thing!
You get the idea?
You need to clean up your machine and stop visiting websites, downloading bad software, etc. Spyware doesn't just magically grow on your computer. You have to do something that lets it get installed. So step one is get a copy of lavasofts adaware and/or Spybot Search and Destroy and clean up your machine. Second step is to figure out what the heck you're doing that causes you to get spyware and stop that behavior!!!!
Now be a good internet citizen and go clean up your computer!
PostPosted: Fri Sep 10, 2004 4:52 pm
Contributing Writer
Contributing Writer
I like using Dexter's voice in my head when I read your posts. One of these days you'll decide to flame someone, and when you do, please write "you are stoooopid, you are stoooopid." I'd enjoy that.
That is all.
PostPosted: Fri Sep 10, 2004 7:26 pm
Sheesh... :roll:
I think I see a pattern developing here. You keep going to the same places, then you get spyware from them each time you go there?
Le'me summarize part of what Dexter said... In three words:
Stop going there!
And I whole-heartedly agree with One4yu2c.
 Post subject: but
PostPosted: Sat Sep 11, 2004 9:40 am
What if it is a place you normally like to hang out?
What if you don't know which sites were having this issue?
AAAND! WHAT IF YOU JUST SIMPLY LIKE TO LOOK AROUND???
PostPosted: Sun Sep 12, 2004 5:10 am
7yrs+11,000 Posts
7yrs+11,000 Posts
That is all.
lol
 Post subject: Re: but
PostPosted: Sun Sep 12, 2004 7:40 am
I'd rather be modding!
Get a firewall
Run the Spybot SD Immunizer (after you scan with it and Adaware)
Block all cookies in your browser
Disable cache and history
Don't use IE
Don't use an "always on" type of connection
Proxy when possible or develop some type of scraficial device on a home network.
Always close your browser completely after visiting known sites with spyware and then Run your Spybot SD and Adware.
Or
Just don't go there.
Joking aside - you should do some of the above anyway. And to find out which site are the issue you can run the scanners after you visit each site.
Manta
PostPosted: Sun Sep 12, 2004 8:23 am
*comedy 'use linux' answer*
