It is currently Sun Jan 25, 2015 7:21 am
 Post subject: Can't get XP Tweak to work
PostPosted: Sat Sep 04, 2004 9:16 am
I am trying to get the 20% bandwidth restriction tweak to work. First, I do not have a gpedit.exe on my system. My network connection does have quality of service enabled, but it won't let me configure or do anything with it. All of the other tweaks I tried worked great.
Dennis
 Post subject: Re: Can't get XP Tweak to work
PostPosted: Sun Sep 05, 2004 12:37 pm
BANNED
BANNED
Dennis
Maybe you should get that file you are missing.
I use Limewire, and I can get lots of files, even programs, for Windows
PostPosted: Mon Sep 06, 2004 12:23 am
team psycho or sumthin
NO
gpedit is for XP pro,you start adding windows services from a third party download you are asking for trouble
 Post subject: Can't get XP tweak to work
PostPosted: Mon Sep 06, 2004 9:24 am
Thanks anyway. It's not that big of a deal anymore. I got the new Ad Aware SE and REMed a bunch of uneeded crap out of the startup area and things are a LOT better now. Thanks!
PostPosted: Thu Sep 09, 2004 8:29 am
it's not "gpedit.exe" it's "gpedit.msc" I'm running XP Pro and made this mistake when I tried doing this tweak as well. I got the tweak to go in just fine after changing the file type and now my cable connection is a whole lot faster.
PostPosted: Thu Sep 09, 2004 3:22 pm
Thanks, I looked for gpedit.* but I don't have any of the gpedit files; I am using XP home. We just got a "safe" computer. Dell built, safe meaning if something goes wrong, someone ELSE has to fix it and not ME for a change. That is one plus of not building your own system. I still miss a good tweakable Abit motherboard though...
PostPosted: Thu Sep 30, 2004 12:22 pm
This file is only available in XP Pro to the best of my knowledge.
PostPosted: Thu Sep 30, 2004 4:33 pm
Folding Momerator
Folding Momerator
Can you post a link to this 20% bandwidth restriction tweak?
Thanks
PostPosted: Fri Oct 01, 2004 5:53 am
Here it is. you'll have to scroll down a few, but it's here
http://www.maximumpc.com/features/featu ... 02-16.html
PostPosted: Sat Oct 02, 2004 5:01 pm
Folding Momerator
Folding Momerator
Thank you!
PostPosted: Sat Oct 02, 2004 5:34 pm
Smithfield*
Smithfield*
oooo i likes. dc++ is rocking now
PostPosted: Wed Oct 06, 2004 1:46 am
Folding Momerator
Folding Momerator
I've been having connection issues with Comcast for the last week. It gets so bad I had to shut down, pull the plug on the modem for a few, then restart. So far, since I did this 20% tweak, all is well :lol:
PostPosted: Thu Oct 07, 2004 4:49 pm
Folding Momerator
Folding Momerator
Is there a way to do this with XP Home?
PostPosted: Thu Oct 07, 2004 5:19 pm
i dont think so, and if i remember right the 20% reserve is for a network....i dont see how 20% can hurt a 1.5-6Mbps connection when the ethernet card runs at 100Mbps,unless for some reason it will only run at 10Mbps but i dont know why it should.
dont even think about asking me about the mobo's with 10/100/1000 intergrated ethernet.
BTW:open task manager > networking tab and look at the link speed
PostPosted: Mon Oct 11, 2004 4:49 pm
Folding Momerator
Folding Momerator
I was talking to some guy at Radio Shack the other night, he said there are 2 sites that have free downloads to tweak XP's connection, Speed Guide & Cable Nut. At the 1st site, your looking for TCPoptimiser (look under broadband- broadband tools). Haven't checked out the other one yet.
