It is currently Fri Jan 30, 2015 6:02 pm
 Post subject: Ghosting software
PostPosted: Sat Aug 28, 2004 6:01 am
hey can anyone help me find a good open source ghosting program?
Thanx
 Post subject: Re: Ghosting software
PostPosted: Sat Aug 28, 2004 7:13 am
I'd rather be modding!
Thanx
Crap, I forgot it....there is one called drvimage.exe I think. Its something like that. There are two with the same name (drive image or something). You want the free one.
I haven't tried it - but I hear it works fine.
XP mag recommended it IIRC
Manta
PostPosted: Sat Aug 28, 2004 9:28 am
I think Manta is trying to think of Partition Image
http://www.partimage.org/
Easier thing though...go hit the manufacturer's site...every utility disk I've seen has this function on there.
PostPosted: Sat Aug 28, 2004 9:31 pm
team psycho or sumthin
my seagate drives came with a utility's disk and one of the utility's will let me copy partitions.....will this work as a ghost utility?
PostPosted: Sun Aug 29, 2004 5:56 am
Naw, I found it "drvimageXP 2.2"
http://www.softpedia.com/public/cat/13/2/13-2-39.shtml
Like I said, I haven't used it - but WinXP mag (I'm pretty sure it was them) recommended it.
unlike ghost, this program doesn't appear to create an "image" as much as it creates a "mirror". But in pratice, I am not sure the difference will matter. It might though - depends on what the description means by "mirror"
EDIT - It looks like it does create an image file and not just clone a partition - END EDIT
partition image might be as good or better a solution.
I say check them both out - use the best one and ALWAYS test freeware of this type before using them for real. After all, most freeware is not a critical application and if it fails - well no biggie. But if these fail just when you need them it might be a serious PITA
Manta
BTW - I like that site (softpedia)
PostPosted: Mon Sep 13, 2004 1:44 pm
Do these work for say taking a SATA drive thats empty and then transfering everything (drives and all) from the old (IDE ) drive to the new SATA drive then moving the old drive out?
??? or dop i actually have to get norton Ghost. but 60 bucks is allot for something ill use once.
