It is currently Tue Jan 27, 2015 1:32 pm
 Post subject: NERO Question ?
PostPosted: Fri Aug 27, 2004 4:09 pm
I currently have a Cyberdrive CD-RW (16x12x40) which uses the OEM version of NERO Burning ROM that came with it. I have ordered an Optorite DVD+-/RW that is coming with NERO Express 6.
Here is the question:
AHEAD NERO site says that the OEM software will only work with the drive it was packaged with. So, does that mean that I will have to have both versions of NERO on my comp to burn with whatever drive I choose ?
Burn DVD, use NERO Express 6 for the DVD-RW drive.
Burn CD-R, use NERO Burning ROM for the CD-RW drive.
I know the DVD-RW will burn CD-Rs, but I was just wondering.
SPECS:
Athlon XP3000+
1024mb PC3200 Kingston
GeForce FX5900
WIN XP HOME
Thanks for any help :D
PostPosted: Fri Aug 27, 2004 9:08 pm
no, nero express 6 will support both drives
from nero's site:
http://www.nero.com/en/632012038142166.php
"All CD, Combo and DVD recorders manufactured since 1997 should be supported by Nero 6.0.0.0 and higher through our SmartDetect (TM) technology which dynamically detects and supports new drives. The version numbers listed under "supported since" indicate the version from which the drive was officially entered into Nero┬┤s internal drive database. However thanks to SmartDetect (TM) technology, even if a drive has not been registered, it should still be supported."
PostPosted: Sat Aug 28, 2004 2:43 am
Thanks. I was hoping this was the case. Now I can get rid of NERO Burning ROM and go with ONE program for burning. Seemed a little bit of a pain to have 2 programs to run the drives.
Once again, thanks
PostPosted: Sat Aug 28, 2004 5:21 am
no problem :)
 Post subject: Re: NERO Question ?
PostPosted: Sun Aug 29, 2004 6:26 am
Sailorman
Sailorman
I wouldn't throw away my software just yet was I you. Test it first. That article said nothing about OEM versions, just retail. Some OEM versions of Nero do indeed only work with the drive they came packaged with.
Of course you may be able to update the program you prefer to a full version of Nero which would work with any drive.
PostPosted: Mon Aug 30, 2004 12:47 pm
DOH!! good catch :)
when I read that I was thinking "coming with" meant bought an oem copy along with the drive
PostPosted: Mon Aug 30, 2004 12:52 pm
4everscream2k4
sorry dude, :( I miss read your post...Nightcrawler is right, the oem copy that comes with your drive probably won't work with any other drives
PostPosted: Sat Sep 04, 2004 5:36 pm
Not always. There has been times where I install using an OEM CD, and just downloaded the latest update for that version (5.5.x or 6.x) and it will work. That way you shouldn't have to have multiple copies installed.
