It is currently Tue Mar 31, 2015 5:42 pm
 Post subject: Password Protect Windows XP Shared Folder
PostPosted: Thu Aug 26, 2004 3:49 am
First off I am on Windows XP Professional. I want to share a folder with another computer over the network, but I wish to password protect the folder. Neither of the computers are part of a domain.
Is there are simple way to do this? I looked it up on Google and all I saw was changing stuff under Permissions. That seemed to only work if you were part of a domain though.
Thanks in advance
PostPosted: Thu Aug 26, 2004 5:16 am
this may be your answer
Click Here
 Post subject: Re: Password Protect Windows XP Shared Folder
PostPosted: Thu Aug 26, 2004 6:41 am
Thanks in advance
from Windows Explorer (not IE), Tools -> Folder Options -> View -> Uncheck User Simple File Sharing.
sorry can't test this out for you, but that has worked for me in the past. both my work and home machines are in a domain.
PostPosted: Thu Aug 26, 2004 6:50 am
Unchecking User Simple File Sharing did the trick. Thanks a lot for the help.
