It is currently Mon Mar 30, 2015 6:28 am
 Post subject: Windows XP, Removing IExplore+MSNGame Zone etc...
PostPosted: Tue Aug 24, 2004 8:58 pm
I am some what new to WinXp, and I'm having a major problem with it.
Can anyone inform me how i can remove Iexplore, Netmeeting, MsnGaming Zone, and soo on. Basiclly the problem is that i am not allowed to remove certain programs that I dont want. When i check the properties of these files it states that they are read-only and it want allow me to uncheck it.
Surely XP doesn't operate in this manner? Or should I just go back to 3.1 or 95, atleast then i could control my computer!!!! :x :x :x
PostPosted: Tue Aug 24, 2004 10:49 pm
try going to start -> settings -> control panel -> click on "add re
PostPosted: Tue Aug 24, 2004 10:50 pm
oopsss i click on post by accident. now try clicking start -> settings -> control panel -> and then click on "add remove programs." then click on "add/remove windows components" and go from there. i dont know if this will help but try it. good luck
PostPosted: Wed Aug 25, 2004 2:09 pm
team psycho or sumthin
open My Computer.... go to tools>folder options and on the view tab select "show hidden files and folders" then Uncheck "hide extensions for known file types" and "hide protected operating system files".
microsloth put hidden stuff on yer pc
now go to c:\windows\inf\sysoc.inf
ok in sysoc.inf you will see stuff like this
msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,HIDE,7
make it look like this
msmsgs=msgrocm.dll,OcEntry,msmsgs.inf,,7
remove any "hide" tag ya see and then you can use add/remove windoze BS
