It is currently Sun Mar 01, 2015 9:03 am
 Post subject: XP Install Help
PostPosted: Sat Aug 21, 2004 8:48 am
I am trying to install xp home on computer for my brother-in-law. It is a fresh install and I used the Seagate utl disk that came with the drive to fromat.
When I put the xp install disk in it loads some files (about 10sec worth) and then says: setupdd.sys could not be loaded error code 4.
Then if I let it reboot and try and boot from the cd it says ntldr is missing.
I am trying to get this done by tonight so he can take it with him college so I need help asap.
thanks,
radbrad
p.s. when did the forum move, I haven't been around in awhile
PostPosted: Sat Aug 21, 2004 9:43 am
could be a bad copy of windows xp. try another cd and see what happens. im not saying anything dealing with warez because its not allowed you and most likely i will get booted out.
 Post subject: Re: XP Install Help
PostPosted: Sat Aug 21, 2004 9:52 am
I'd rather be modding!
thanks,
radbrad
http://support.microsoft.com/default.as ... -us;330181
Specs?
Also, I think you can deleate the other thread to get rid of it.
Manta
Oh Yeah - and this sould likely have gone in the free clinic as well. Yer battin' 1000 :)
The Commport still exists at Delphi. Its just that this is now the official site
PostPosted: Sat Aug 21, 2004 1:03 pm
How large is the drive? You might want to attempt another re-install and delete all existing partitions.
PostPosted: Mon Aug 23, 2004 8:30 am
that usually happens when there's a floppy disk in the drive, or other unbootable devices.
PostPosted: Mon Aug 23, 2004 5:36 pm
It happens when the OS is not completely installed. Ntldr is the boot loader for XP - if the install didn't finish, it isn't there (on the HDD).
I wanted him to check hardware so we could see if what he has is incompatable with XP.
Then we could move on to loooking at specific parts (like a HDD with a bad boot sector)
Manta
